02-12-2013 03:11 AM - edited 03-19-2019 06:15 AM
Hello.
I like to add a VG202 Analog Adapter to the system. But for that device i have to upgrade from 12.4(15)XZ2 with CUCME 7.0(0) to 12.4(24)T2 with CUCME 7.1(0). I didnt find any good inforamtion about upgrade.
Is that an easy upgrade, just upload the IOS and the CME files or are there some hints to know.
I do that upgrade on a runnning system with about 50 SCCP Phones.
Thanks in advance Patrick
Solved! Go to Solution.
02-12-2013 05:26 AM
Hi Patrick,
Good questions
You can upgrade the IOS on a router and not lose the CME config, licenses etc.
There may be some work that needs to be done after the upgrade to load the
new CME GUI version etc.;
From Tommer and Hari;
https://supportforums.cisco.com/message/3048406#3048406
From Brandon and Kshitij;
https://supportforums.cisco.com/message/1323866#1323866
Cheers!
Rob
"Clocks go slow in a place of work
Minutes drag and the hours jerk"
-The Clash
02-12-2013 05:26 AM
Hi Patrick,
Good questions
Cheers!
Rob
-The Clash
