Heads Up :
The post you are writing will appear in a public forum. Please ensure all content is appropriate for public consumption. Review the employee guidelines for the community here.
I'm looking to upgrade our 10.0.1 install to 10.5.2 and can't find any guides that don't involve using a Prime Deployment server. Is the upgrade guide for 10.0 a good guide to follow? We currently only use the 10.0 server to manage 5 video endpoints right now for testing. So, it's a test bed CUCM basically.
Same process we've had ever since we moved to a Linux appliance is the one you need to follow, you can follow the 10.0 guides for that matter, simply use 10.5 media.
java
if this helps, please rate
Learn, share, save
