VG-204 SIP - PSTN outbound not happening from CUCM
dhananjeyan_t
I have VG204 configured as SIP , SIP trunk is established to CUCM 7.x , Outbound to PSTN calls is not happening but Extension dialing  within CUCM DB is happening. Inbound from PSTN works.
Call manager is not forwarding the calls initiated from vg204 extn to PSTN gateway .
Pls assist if i am missing something on vg204 or CUCM for outbound calls to happen .
, the error log on cucm  is
SIP/2.0 404 Not Found
Reason: Q.850;cause=1
version 15.1
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
no service dhcp
boot-start-marker
boot system flash:vg20x-advipservicesk9-mz.151-3.T3.bin
boot system flash:
boot-end-marker
aaa session-id common
clock timezone GMT 0 0
no ip source-route
ip cef
no ip bootp server
no ip domain lookup
no ipv6 cef
voice call send-alert
voice rtp send-recv
voice service voip
no ip address trusted authenticate
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol pass-through g711alaw
modem passthrough nse codec g711alaw
sip
  bind control source-interface FastEthernet0/0
  bind media source-interface FastEthernet0/0
  redirect contact order best-match
voice class codec 2
codec preference 4 g711alaw
codec preference 5 g711ulaw
voice class sip-profiles 1000
request ANY sip-header User-Agent modify "User-Agent: Cisco-SIPGateway.*" "User-Agent: Cisco/v11 r1/alg01"
request ANY sip-header Server modify "Server: Cisco-SIPGateway.*" "Server: Cisco/v11 r1/alg01"
response ANY sip-header Server modify "Server: Cisco-SIPGateway.*" "Server: Cisco/v11 r1/h2p-vg-alg01"
response ANY sip-header User-Agent modify "User-Agent: Cisco-SIPGateway.*" "User-Agent: Cisco/v11 r1/alg01"
response ANY sip-header Remote-Party-ID remove
request ANY sdp-header Attribute modify "a=rtr" "a=X-nortr"
response ANY sdp-header Attribute modify "a=rtr" "a=X-nortr"
voice vad-time 1000
voice-card 0
application
package callfeature
  param long-dur-disc-cause 21
  param long-dur-duration 1440
  param long-dur-action disconnect
  param long-dur-call-mon enable
service dsapp
  param callWaiting FALSE
  param blind-xfer-wait-time 2
  param callTransfer TRUE
global
  service default dsapp
archive
log config
  hidekeys
dial-control-mib retain-timer 1440
dial-control-mib max-size 500
ip tftp source-interface FastEthernet0/0
ip address 10.10.10.13 255.255.255.224
ip access-group al_trusted_SIP in
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
load-interval 60
speed 100
full-duplex
arp timeout 420
control-plane
voice-port 0/0
no snmp trap link-status
timeouts interdigit 4
description h2p/01
station-id name Analog phone
station-id number 26999
caller-id enable
voice-port 0/1
description h2p/02
station-id number 26998
caller-id enable
voice-port 0/2
description h2p/03
station-id number 26997
caller-id enable
voice-port 0/3
description h2p/04
station-id number 26996
caller-id enable
mgcp profile default
dial-peer voice 1100 voip
permission orig
description Incoming from IP network
huntstop
session protocol sipv2
incoming called-number .
voice-class codec 2
voice-class sip profiles 1000
dtmf-relay rtp-nte
dial-peer voice 1210 voip
description SIP registrar server
huntstop
preference 4
destination-pattern .T
session target ipv4:10.10.10.15
voice-class codec 2
dtmf-relay sip-notify
dial-peer voice 99900 pots
description Analog phone
huntstop
preference 4
destination-pattern 26999
progress_ind alert strip
port 0/0
dial-peer voice 99901 pots
huntstop
preference 4
destination-pattern 26998
port 0/1
dial-peer voice 99902 pots
huntstop
preference 4
destination-pattern 26997
port 0/2
dial-peer voice 99903 pots
huntstop
preference 4
destination-pattern 26996
no digit-strip
port 0/3
dial-peer hunt 2
no dial-peer outbound status-check pots
gateway
media-inactivity-criteria all
timer receive-rtcp 5
timer receive-rtp 1200
sip-ua
retry invite 3
registrar 1 ipv4:10.10.10.15 expires 3600
g729-annexb override
dhananjeyan_t
Can someone assist me pls.
