Visual Voicemail - jad midlet not found
ronaldo.gama
Beginner
Beginner
I have an implementation of Visual Voicemail on Unity Connection 8.5/CUCM 8.5.
When I try to access the page http:// <IP Unity Conection> / midlets / VisualVoicemail / VisualVoicemail.jad, I get the response file not found.
What´s wrong?
Ronaldo Gama
5 Replies 5
Lucas Vieira
Beginner
Beginner
I have exaclty the same problem.
Someone can answer??
I entered on the phone logs, and It says:
Install exception: Missing suit name and a lot more things.
I do not know if it helps (my unity Connection version is 8.6) but I have tried with http://Unity_Connection_IP_Address/midlets/RT/VisualVoicemail.jad and it worked.
mikeduffy13
Beginner
Beginner
Make sure you don't have a space in your service name.  ie: Visual Voicemail instead of VisualVoicemail.  There cannot be a space.
Lucas Vieira
Beginner
Beginner
Ronaldo,
On all fields of the configuration, you have to put the Hostname of the Unity, not the IP address.
This resolved for me!
mislam
Beginner
Beginner
I made it working.
Service Name = VisualVoicemail
ASCII Service Name=VisualVoicemail
Service URL=http:///midlets/VisualVoicemail/VisualVoicemail.jad
Service category = Jave midlet
Service type = Messages
Service Provide=cisco
check = enable
Remember that there should not be any space in service Name.
Check that Service URL is working using the above URL in browser. If you see download pop-up, then the url is correct.
Recognize Your Peers
