09-20-2025 04:37 AM
Hi. I have a Cisco ISR921 router. Can I use it as a voice gateway to establish sip trunk connection with SBC?
I don't have voice commands on that and I can't see UCK9 license on that.
Solved! Go to Solution.
09-20-2025 06:19 AM - edited 09-20-2025 06:20 AM
Hello @Raminkn20
isr921 cannot be used as a voice Gw or CUBE because it lacks DSP resources... voice features and ucK9 licensing !!! It is designed/used only for routing and branch conectivity.
09-21-2025 02:24 AM
Hello @Raminkn20
See series catalyst 8200/8200L.
These are newer routers that many are using as sucessors to the older ISR and voice gateway platforms.
Read this:
Hello @Raminkn20
09-20-2025 09:53 PM
Do you have any suggestion to use as a voice gateway for small business?
ISR 4000 series are end of sale and I can't find an appropriate one.
09-21-2025 02:24 AM
Hello @Raminkn20
Read this:
