Voicemail - PSTN
Marcos Cardoso
Hello everyone,
I am facing an issue that is driving me crazy.
I have a CUCM 8.6 integrated to CUC 8.6 via SIP. All my features are running properly, however when I try to call the VM Pilot from the PSTN I got a message that the user is busy on my gateway:
Calling Party Number i = 0x2183, '11974954XXX'
                Plan:ISDN, Type:National
        Called Party Number i = 0x81, '65XX'
                Plan:ISDN, Type:Unknown
Oct 10 11:45:32.715 gmt: ISDN Se0/1/0:15 Q931: Received SETUP  callref = 0xA49B callID = 0x0C82 switch = primary-net5 interface = User
Oct 10 11:45:32.719 gmt: ISDN Se0/1/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0xA49B
        Channel ID i = 0xA9838C
                Exclusive, Channel 12
Oct 10 11:45:32.831 gmt: ISDN Se0/1/0:15 Q931: TX -> ALERTING pd = 8  callref = 0xA49B
Oct 10 11:45:32.891 gmt: ISDN Se0/1/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0xA49B
        Cause i = 0x8091 - User busy
Oct 10 11:45:32.951 gmt: ISDN Se0/1/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x249B
Just to add more info, I have another service using the same SIP TRUNK into the Unity that is AA that is working fine. All calls from PSTN is completed.
Please, could you help me on it?
Thanks in advance
MC
michael o'nan
Level 4
Level 4
Do you have translation or route pattern configs you can share?
Hi Michael,
I have these translation on gateway:
voice translation-rule 1
 rule 3 /^3/ /33/
 rule 4 /^4/ /34/
 rule 5 /^5/ /35/
 rule 6 /^6/ /36/
 rule 7 /^7/ /37/
And about the route pattern, I have attached an image from CUCM
Thnaks in advance for your help.
