Way to find the licences and Versions
Mujeeb Shaik
Beginner
Beginner
How  Do I Find the versions, licences installed on a CUCM (BE6K) running in my office, also need to the same on the connected 2901 gateway, what commands to be used here
Need to get the details of all the components like unity connection and presence , these are in production here.
Aman Soi
Advisor
Advisor
from CLI of Pub/sub, using putty , u can run command " show version active"
Also, from CUCM GUI , you can click on Help---About
for user licenses,u can login into ELM/PLM and check license usage.
For router, u can use show licenses detail
show licenses feature
regds,
aman
Recognize Your Peers
