WebEX unit configuration
is.admin
There is a WebEX unit having issue calling external meeting room in our corporate network. It works fine if make and receive calls internally. This has never worked before externally.
I noticed that there is a proxy IP address 101.178.102.4 under the SIP setting of the unit.
I was told to whitelist below traffic to allow traffic between the site unit and Cisco WebEX. My question is what's the purpose of the Proxy server with IP 101.178.102.4 and will the unit try to talk to the proxy first, once connection established, the proxy will take over and route the traffic to wherever it needs to go to? What should I do to get the call going on the external resource?
List of IP address ranges used by Cisco Webex Meeting services:
  • 68.96.0/19 (CIDR) or 64.68.96.0 - 64.68.127.255 (net range)
  • 114.160.0/20 (CIDR) or 66.114.160.0 - 66.114.175.255 (net range)
  • 163.32.0/19 (CIDR) or 66.163.32.0 - 66.163.63.255 (net range)
  • 133.128.0/18 (CIDR) or 170.133.128.0 - 170.133.191.255 (net range)
  • 39.224.0/19 (CIDR) or 173.39.224.0 - 173.39.255.255 (net range)
  • 243.0.0/20 (CIDR) or 173.243.0.0 - 173.243.15.255 (net range)
  • 182.160.0/19 (CIDR) or 207.182.160.0 - 207.182.191.255 (net range)
  • 197.192.0/19 (CIDR) or 209.197.192.0 - 209.197.223.255 (net range)
  • 151.128.0/19 (CIDR) or 216.151.128.0 - 216.151.159.255 (net range)
  • 29.192.0/19 (CIDR) or 114.29.192.0 - 114.29.223.255 (net range)
  • 4.192.0/20 (CIDR) or 210.4.192.0 - 210.4.207.255 (net range)
  • 26.176.0/20 (CIDR) or 69.26.176.0 - 69.26.191.255 (net range)
  • 109.192.0/18 (CIDR) or 62.109.192.0 - 62.109.255.255 (net range)
  • 26.160.0/20 (CIDR) or 69.26.160.0 - 69.26.175.255 (net range)
Webex website, Webex Desktop App/Productivity Tools, Webex Meetings for Android/iOS, Webex Web App
Protocol
Port Number(s)
Direction
Access Type
TCP
80 / 443
Outbound
Webex Client Access port
TCP/UDP
53
Outbound
DNS
UDP
9000
Outbound
Webex Client Media for Webex Events (Audio Streaming)
UDP
9000
Outbound
Webex Client Media (VoIP and Video RTP)
TCP/UDP
Operating System Specific Ephemeral Ports
Inbound
Return traffic from Webex
Anurag Srivastava1
and will the unit try to talk to the proxy first, once connection established, the proxy will take over and route the traffic to wherever it needs to go to? -->Yes that is correct, your unit is registered with webex cloud and it will send all the calls to webex first and then they will route the call to destination.
Do you mean external resources by other domains or other businesses?
You need to open a case with Cisco TAC to see what is exactly happening at proxy side.
Please rate if it is helpful...
Please rate if it is helpful and mark as accepted solution if applicable....
Hi, thanks a lot for your reply.  I was just trying to figure out the route is selected on the router when the call is placed. So let me confirm to make a call either internally (within corporate network) or externally (with resource outside of the corporate network) the WebEX MX300 must talk to the proxy first and then traffic gets routed to Cisco WebEX servers from where the proxy is at.
My original thought was like the MX300 would talk directly to the Cisco WebEX servers. So the firewall policy to whitelist those Cisco WebEX servers and range of ports should be placed on the firewall as close to the proxy right?
