04-11-2013 06:42 AM - edited 03-19-2019 06:34 AM
Please I need your help,
What hardware is required to activate application like Cisco Unity® Connection ?
Thank you
04-11-2013 06:45 AM
is this what your after?
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/9x/supported_platforms/9xcucspl.html
04-11-2013 06:55 AM
In addition to great reply (+5), basically this is similar to CUCM which you need to have in order to run Unity Connection (or you could have CME). So, if you have CUCM running it will be very similar concept. If this is new install you want to definitely go the virtual path.
HTH,
Chris
