What is the maxium distance for analog FXS ports?
Kris Garner
I have a customer that has phones that are 2.2 miles away on their campus.  We're positioning a C3945-112FXS gateway .  Will the FXS ports support a phone at this distance?  What is the max distance it can support?
Thank you in advance.
paolo bevilacqua
That 'may' work, but is already outside specifications.
http://www.cisco.com/en/US/prod/collateral/modules/ps5365/product_data_sheet0900aecd801c595e.html
table 6
the regular FXS are made on-premise se only. the VIC3-2EXFS allows a longer disyance
Table 7.
You should install the device close where the phones are.
