01-27-2015 05:58 PM - edited 03-19-2019 09:06 AM
I have a MRG consists of two CFB, it is found one is registered with CCM, the other is not. some users complain that the ad-hoc conference soft button is not working. So is that due one of the CFB is not registered? (I know all same type of resource within a MRG will be round-robin balanced).
will happen Call Manager allocate an unregistered CFB?
01-27-2015 07:16 PM
It will not allocate the unregistered one. Media Resource Manager will look for the available resources registered with CUCM according to the configuration and allocate the one thats available.
-Terry
Please rate all helpful posts
01-29-2015 10:11 AM
You can use RTMT tool for reports on resource allocation, and verify if the registered CFB is totally used when the issue happens. You should fix the issue with the unregistered CFB.
