04-01-2016 11:03 AM - edited 03-19-2019 10:56 AM
Does anyone know how to change the ringing of lines on a wireless headset to be flash only? User is using phone with a wireless headset with multiple lines but all the lines are ringing in the headset; I went into the lines and changed
Ring Setting (Phone Idle)
Ring Setting (Phone Active)**
both to Flash, but it still rings in the headset.
Thank you,
Lisa
04-01-2016 11:20 AM
Hi Lisa,
There are some known bugs related to this issue. You may need to provide the phone model and firmware version they are running. Here is one such bug;
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuh22404
Symptom:
Headset using Enhanced Headset Control (EHC) integrated via Aux port beeps for a new incoming call even though line is set to flash-only in CUCM.
Conditions:
This applies when using a headset integrated with EHook functionality with line configuration set to flash-only.
Workaround:
Set ring setting to disabled on line to stop beeping on incoming calls. Can also downgrade to 9.2.1SR1 or earlier firmware.
04-01-2016 11:20 AM
thanks for the information, I will check it out. Most appreciated.
04-01-2016 01:12 PM
This worked! Thank you so much for the information, very helpful.
04-02-2016 07:54 AM
Hi Lisa,
You are most welcome my friend! Glad to be of some small help here.
Cheers!
Rob
