wireless headset/disable ringing of lines to only flash
tsp1lrk777
Does anyone know how to change the ringing of lines on a wireless headset to be flash only? User is using phone with a wireless headset with multiple lines but all the lines are ringing in the headset; I went into the lines and changed
Ring Setting (Phone Idle)
Ring Setting (Phone Active)**
both to Flash, but it still rings in the headset.
Thank you,
Lisa
Rob Huffman
Hi Lisa,
There are some known bugs related to this issue. You may need to provide the phone model and firmware version they are running. Here is one such bug;
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuh22404
Symptom:
Headset using Enhanced Headset Control (EHC) integrated via Aux port beeps for a new incoming call even though line is set to flash-only in CUCM.
Conditions:
This applies when using a headset integrated with EHook functionality with line configuration set to flash-only.
Workaround:
Set ring setting to disabled on line to stop beeping on incoming calls. Can also downgrade to 9.2.1SR1 or earlier firmware.
7945/7965 EHook headset beeping when line set to flash only
CSCuh22404
thanks for the information, I will check it out. Most appreciated.
This worked! Thank you so much for the information, very helpful.
Rob Huffman
Hi Lisa,
You are most welcome my friend! Glad to be of some small help here.
Cheers!
Rob
