Yet another email notification problem
blizmanyu
Ok, I have the UC540 with CUE 7.0 and CME 7.1. I've read many different possible problems and solutions to trying to get email notification to work, but none have worked whatsoever. Here's what I get when I trace my voicemail from CUE CLI:
3554 08/03 13:43:25.501 ACCN STGN 0 Task: 37000000091GetListMember: output string:outcall
14462 08/03 13:43:25.581 VMSS mnot 0 MessageNotification: Enter insertIntoMsgNotifQueue(): msg recipient: blizmanyunotif target: blizmanyu
14462 08/03 13:43:25.631 capi smtp 0 SmtpServer: getSysdb(): Attribute: address
2223 08/03 13:43:25.632 capi smtp 0 SmtpSysdbNode: get(): address
14462 08/03 13:43:25.633 VMSS mnot 0 MessageNotification: query: INSERT INTO out
call_email_job VALUES ('blizmanyu', 18, 1312393405583, 15, 0, 'blizmanyu');
14462 08/03 13:43:25.663 VMSS mnot 0 MessageNotification: Notifying sender threads
14462 08/03 13:43:25.663 VMSS mnot 0 MessageNotification: Exit insertIntoMsgNotifQueue(): notifyEmailThread=true, notifyPhoneThread=false
2824 08/03 13:43:25.748 VMSS mnot 0 EmailSender: Processing job: 1
2824 08/03 13:43:25.788 VMSS mnot 0 EmailSender: Got a job: Owner=blizmanyu, Contact=yblizman@nwelec.com, UID=15
2824 08/03 13:43:25.792 VMSS mnot 0 EmailSender: sendEmailNotification: checkSendPreConditions passed
2824 08/03 13:43:25.792 capi smtp 0 SmtpServer: getSysdb(): Attribute: address
2237 08/03 13:43:25.794 capi smtp 0 SmtpSysdbNode: get(): address
2824 08/03 13:43:25.795 capi smtp 0 SmtpServer: getSysdb(): Attribute: port
2235 08/03 13:43:25.797 capi smtp 0 SmtpSysdbNode: get(): port
2824 08/03 13:43:25.798 capi smtp 0 SmtpServer: getSysdb(): Attribute: userid
2227 08/03 13:43:25.800 capi smtp 0 SmtpSysdbNode: get(): userid
2824 08/03 13:43:25.801 capi smtp 0 SmtpServer: getSysdb(): Attribute: password
2223 08/03 13:43:25.803 capi smtp 0 SmtpSysdbNode: get(): password
2824 08/03 13:43:25.803 capi smtp 0 SmtpServer: getSysdb(): Attribute: authRequired
2237 08/03 13:43:25.807 capi smtp 0 SmtpSysdbNode: get(): authRequired
2824 08/03 13:43:25.807 VMSS mnot 0 EmailSender: Begin processing email job, UID=15
2824 08/03 13:43:25.841 VMSS mnot 0 EmailSender: Attachment body part added, UID=15
2824 08/03 13:44:06.110 VMSS mnot 0 EmailSender: Error sending email, UID= 15 :javax.mail.SendFailedException: Sending failed;
  nested exception is:
        class javax.mail.MessagingException: Unknown SMTP host: pod51009.outlook.com;
        java.net.UnknownHostException: pod51009.outlook.com - The operation timed out
2824 08/03 13:44:06.110 VMSS mnot 0 EmailSender: Send email rc=2
2824 08/03 13:44:06.110 VMSS mnot 0 EmailSender: Deleting email job: Device ID=18, UID=15
2824 08/03 13:44:06.159 VMSS mnot 0 EmailSender: calculateWaitTime(): current time: 1312393446157, job time: 0
2824 08/03 13:44:06.159 VMSS mnot 0 EmailSender: Wait time=0
So when I ping pod51009.outlook.com, it hangs for a while then gives me an 'unknown host' error. The server is definitely correct and my DNS settings are also correct (I used OpenDNS for the above testing). I also configured my NAT in CCA to allow 10.1.10.1 to route through my WAN (71.XX.XX.XX). I've also tried to use gmail's smtp, hotmail's smtp, and several free smtp relays I've randomly found and picked from the web and all give similar results/errors. Any suggestions?
Thanks in advance,
Yutaka
phamvinhdat
Level 3
Level 3
Instead of hostname, can you try the actual ip address for smtp.
Dat
It couldn't connect and just timed out:
3555 08/04 08:56:14.910 ACCN STGN 0 Task: 37000000124GetListMember: output strin:outcall
15551 08/04 08:56:14.971 VMSS mnot 0 MessageNotification: Enter insertIntoMsgNotifQueue(): msg recipient: blizmanyunotif target: blizmanyu
15551 08/04 08:56:15.020 capi smtp 0 SmtpServer: getSysdb(): Attribute: address
2227 08/04 08:56:15.021 capi smtp 0 SmtpSysdbNode: get(): address
15551 08/04 08:56:15.021 VMSS mnot 0 MessageNotification: query: INSERT INTO out
call_email_job VALUES ('blizmanyu', 60, 1312462574972, 20, 0, 'blizmanyu');
15551 08/04 08:56:15.133 VMSS mnot 0 MessageNotification: Notifying sender threads
15551 08/04 08:56:15.134 VMSS mnot 0 MessageNotification: Exit insertIntoMsgNotifQueue(): notifyEmailThread=true, notifyPhoneThread=false
2824 08/04 08:56:15.209 VMSS mnot 0 EmailSender: Processing job: 1
2824 08/04 08:56:15.244 VMSS mnot 0 EmailSender: Got a job: Owner=blizmanyu, Contact=yblizman@nwelec.com, UID=20
2824 08/04 08:56:15.248 VMSS mnot 0 EmailSender: sendEmailNotification: checkSendPreConditions passed
2824 08/04 08:56:15.248 capi smtp 0 SmtpServer: getSysdb(): Attribute: address
2223 08/04 08:56:15.251 capi smtp 0 SmtpSysdbNode: get(): address
2824 08/04 08:56:15.251 capi smtp 0 SmtpServer: getSysdb(): Attribute: port
2235 08/04 08:56:15.254 capi smtp 0 SmtpSysdbNode: get(): port
2824 08/04 08:56:15.254 capi smtp 0 SmtpServer: getSysdb(): Attribute: userid
2237 08/04 08:56:15.257 capi smtp 0 SmtpSysdbNode: get(): userid
2824 08/04 08:56:15.258 capi smtp 0 SmtpServer: getSysdb(): Attribute: password
2227 08/04 08:56:15.260 capi smtp 0 SmtpSysdbNode: get(): password
2824 08/04 08:56:15.260 capi smtp 0 SmtpServer: getSysdb(): Attribute: authRequired
2223 08/04 08:56:15.263 capi smtp 0 SmtpSysdbNode: get(): authRequired
2824 08/04 08:56:15.263 VMSS mnot 0 EmailSender: Begin processing email job, UID=20
2824 08/04 08:56:15.312 VMSS mnot 0 EmailSender: Attachment body part added, UID=20
2824 08/04 08:58:15.404 VMSS mnot 0 EmailSender: Error sending email, UID= 20 :javax.mail.SendFailedException: Sending failed;
        class javax.mail.MessagingException: Could not connect to SMTP host: 207.46.4.146, port: 587;
        java.net.ConnectException: connection to 207.46.4.146 timed out
2824 08/04 08:58:15.404 VMSS mnot 0 EmailSender: Send email rc=2
2824 08/04 08:58:15.404 VMSS mnot 0 EmailSender: Deleting email job: Device ID=60, UID=20
2824 08/04 08:58:15.456 VMSS mnot 0 EmailSender: calculateWaitTime(): current time: 1312462695454, job time: 0
2824 08/04 08:58:15.456 VMSS mnot 0 EmailSender: Wait time=0
I forgot to note in my OP that the server requires TLS [and its default port of 587]. I can't change this requirement, but remember that I've tried several smtp relays, including those that use port 25 and those that don't require authentication and got similar results/errors.
I'm not sure if this means anything, but:
When I ping google.com from CUE, I get the following:
5 packets transmitted, 0 received, 100% packet loss, time 4003ms, ipg/ewma 1000.959/0.000 ms
I'm able to ping my router fine. Anything?
Still having issues with this. When I try to add CUE's IP to the router's routing table using conf ip route 10.1.10.1 255.255.255.255 192.168.10.1, I get an error saying "%Invalid next hop address (it's this router)" . Am I doing this wrong?
