Add automatical directory numbers and device profiles from Active Directory users
Kai Onken
I've two questions.
1. I try to add automatically only all extension numbers from "telephoneNumber" field inside my Active Directory to the directory numbers of my CUCM 8.6.2
I've stored the numbers as follows at my AD users, like +49 89 123456 7890
DescriptionContent
Country code+49
Pre select for town89
Subscribernumber123456
Extension0987
2. I've only the following IP Phone type 7962 at my enviroment. My CUCM 8.6.2 is connected to an Active directory system, where I stored the phone number at the 'phoneNumber' field like I explained above
Now is it possilbe, to generate automatical device profile for each user of the OU which I sync to the CUCM, like e.g. USERID_7962 and add the phone number to the first line?
Thanks for all your help
Kind regards
Kai
Hi Kai,
Not there's no way. Device profile can't be sync from LDAP, it need to be created manually or using bulk administration tool.
Please remember to rate useful posts clicking on the stars below.
Favor calificar todos las respuestas Ăștiles dando click en las estrellas de mas abajo.
___________________________________________
LinkedIn Profile: do.linkedin.com/in/leosalcie
__________________________________________________
