08-21-2019 11:36 AM
Hello again everyone, have a question regarding adding a 2nd extension to a user's Remote Destination. I have a user that is currently tied into a RDP for a hotline that rings his, and two other's cell phones after hours. This user now also wants to add his desk phone to ring him in addition to the hotline.
The issue I am running into is I cannot create a profile for his cell, as it already exists, and I cannot add his direct extension to the RDP that his cell is related to, as this will ring the other two numbers on this RDP. Is there a way I can set this up to have both extensions ring his cell?
Solved! Go to Solution.
08-22-2019 08:09 AM
08-21-2019 12:46 PM
So curious could you not just do a call forward no answer on the desk phone and put the users cell number there with the appropriate CSS to all the phone to call off net. Now this would not give the same experience of simultaneous ringing but the call would roll to the cell after the CFNA time expires. Just a thought. I am sure someone smarter than i will have another solution.
Dennis
08-22-2019 07:21 AM - edited 08-22-2019 07:43 AM
No, the phone is going to voicemail not the cell phone.
Edit: And because I was overthinking this, I realized all I needed to do was use the existing profile and NOT assign the line to the other users on that RDP.
08-22-2019 08:09 AM
Glad you got it resolved.
