After upgrade to latest Device Pack -- auto ring down
dshumake
Level 4
Level 4
After upgrading my call manger to 8.6.2.21900-5 and the latest device pac I am getting to follow issues.
phones types:  7942, 7945,7975, 8941,7962
all phones are affected and the problem move to a difference device
the user pickup the handset or speaker, then the phone will auto dial the last number.  if you reset the phone it will temporary fix. the problem will come back  in a day or two.
Now if we downgrade to 9.2.1 all is good. but the lastest firmware fix a lot other issues.
any ideal what the issues is.
Rob Huffman
Hi Derrick,
It sounds like this bug;
Community Discussion on CSCtz29414 - Cisco Support Community
7975 dial random numbers when off hook
Folks,  We opened a TAC for this, and Cisco got a fix for new defect CSCtz29414  will be made available in the 9.3.1 firmware release, scheduled for  June. Affected Phones for us 7942 7962 7945 7965
Author: ciscoratheeshkumarm    Date: May 1, 2012    Answered: No    Latest activity: May 1, 2012
CUCM 7.1.5 Random auto dial last missed call problem
Cheers!
Rob
"Always movin' ahead and never lookin' back" - Springsteen
we are using the latest device pack for 8.6.2 which came out in July.
Derrick,
What is the firmware version that was installed with the device pack?
Latest device pack does not indicate latest firmware file, I suggest 9.2.3 or 9.3.1 loads.
Chris
Rob Huffman
Hi Derrick,
I believe the latest device pack contains the 9.3.1 firmware but you'll need a
firmware with the "fixed-in" version. I would contact TAC
CSCtz29414 - 7942/7962 - Call History is Auto-Dialed When Pressing Speaker Button
Description
Symptom:
When a 7942/62 phone is  populated with call history records (e.g. received/placed/missed calls),  the endpoint will auto-dial the number contained in its call history  when the speaker button is pressed.
Conditions:
IP Phone Call  History contains Received/Placed/Missed Phone number record prior to  pressing speaker button to go off-hook.  Phone will continue to  auto-dial the number listed in Call History once error condition is  experienced.
Workaround:
Reset IP Phone to clear error condition.
Details
First Found in:                          (1)
9.2(3)
Status:
Fixed
Last Modified:
Aug 02,2012
Fixed in:                          (3)
9.3(1)TH2.2,9.2(3)MN1.22,9.2(3)ES7
Product:
Cisco Unified IP Phone 7900 Series
Platform:
Dependent
Severity:
3 - moderate
Cheers!
Rob
