07-29-2013 07:03 AM - edited 03-19-2019 07:03 AM
I have an interesting request from a user of a system call handler. On slow days, they would like the option to close their office early and force the system to follow it's "closed" routine. I am running Cisco Unity Connection 8.6.2.
I can't think of any way to do this other than to go in on their behalf and drop a short "holiday" into a custom holiday schedule to black out those hours that they would otherwise be open. But I don't want to have to do this every time they ask. Also, if I am not available when they need to close, this causes an inconvenience to them.
Is there a way that they can go into Unity (through a desk set) and move their call handler into a closed status? Or does anyone have a clever way of handling this?
-Steve Ballantyne
Solved! Go to Solution.
07-29-2013 07:18 AM
if you gave the users access to greetings administrator then they could via a TUI enable the alternate greeting (overides all other greeting regardless of schedules etc) and then the after greeting action could follow whatever sequence is required for closed routine.
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/8x/administration/guide/8xcucsag060.html
07-29-2013 07:18 AM
07-29-2013 07:42 AM
Thank you Jeff! Wasn't sure where to begin - but it looks like my path for this is to:
1) Decide who among the users should be in "charge of the call handler" and make them owners of it.
2) Set a Caller Input rule in the call handler that will lead them to Conversation > Greetings Administrator.
Pretty easy from there.
Thanks again for the quick response.
