ata 190 Analog Telephone Adapter will work with CUCM System version: 10.5.1.10000-7
Mahmoud0111
Hello ,,
i have a Cisco Call Manager  System version: 10.5.1.10000-7
i would like to ask this is will work with ATA 190 Analog Telephone Adapter for Fax or no
i need to configure Fax Server or Receiving and sending fax so it will work or no
2 Accepted Solutions
Manish Gogna
ATA 190 will work with CUCM 10.5, for configuring ATA 190 for FAX plz check the following
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cata/190/1_0/english/administration/guide/sip/ATA190/a190_ag7fax.html
Manish
Can you try a different browser or try doing ssh into CLI of the server and check the status of services through "utils service list" command.
Manish
9 Replies 9
Manish Gogna
Manish
i would like to ask is ATA 186 , 187   they will work as well and who is better from 186 and 187
thanks for your reply
You should stick with ATA 190 so that you can get support from TAC. ATA 186 is totally end of support so it is not recommended at all. ATA 187 although still has some more time before it goes end of support but its end of sale as well. If looking at a long term solution you should go for ATA 190. To check for their features and specs just check their datasheet, also check the EOL notices here
http://www.cisco.com/c/en/us/products/unified-communications/ata-180-series-analog-telephone-adaptors/eos-eol-notice-listing.html
Manish
Hello ,,
i would like to update the release notes so i can be able to add ATA 190 Device
Hi Mahmoud,
On this version you will need to install a device pack for cucm 10.5.1 , you can download it from the following link
http://www.cisco.com/web/software/282074299/119338/cmterm-devicepack10.5.1_12020-1_ReleaseNotes.pdf
https://software.cisco.com/download/release.html?mdfid=285963825&softwareid=282074299&release=10.5(1.12020)
Here is the read me file for this device pack which needs to be installed on all servers followed by a cluster reboot.
Alternatively, i checked in my lab on cucm version  10.5.2.11900-3 and it has the option to add ATA 190. You can do a minor upgrade to this cucm version or any other higher 10.5.2 version by downloading from the following link
https://software.cisco.com/download/release.html?mdfid=285963825&flowid=77896&softwareid=282074295&release=10.5(2)SU3a&relind=AVAILABLE&rellifecycle=&reltype=latest
If you have any IM&P integration then it wil also need to be upgraded to a 10.5.2 version.
Manish
thanks alot for your help
i did the install for the update to ATA 190 Device Release notes
and i uploaded the files from cisco and when i restarted the server
and tried to access the server administration
i'm  getting this error
HTTP Status 404 - /ccmadmin/showHome.do
type: Status report
message: /ccmadmin/showHome.do
description: The requested resource is not available"
Manish
Hello Eng : Manish Gogna ,,
the Device (ATA 190 Cisco Analog telephone)  is this will work as fax server so i will received fax throw this device i will add it with callmanager
do i need anything else with it
and what is the steps for configuring the device i'm lost with the documentation
Thanks alot for ur help before:)
If utilizing NSE Fax Pass-through G711ulaw, then you would want to configure the gateway with:
Config t
Voice service voip
Modem passthrough nse codec g711ulaw
You can either configure it globally above or on the dial-peer,  dial-peer configuration will always take precedence over the global config.
If you decide to go with Fax Pass-through then it would be:
Config t
Voice service voip
Fax protocol pass-through G711ulaw
For T.38 you can refer the following guide
http://www.cisco.com/c/en/us/td/docs/ios/voice/fax/configuration/guide/15-2MT/vf_15_2MT_book/vf_cfg_t38_fxrly.pdf
