07-03-2019 08:54 AM
I have a ton of ATA 190's in production on CUCM System version: 10.5.2.12901-1.
These devices constantly become unregistered and have to be reset before they will work again.
I use these for fax machines.
Any idea what causes this?
If you are only connecting one fax machine, does it matter if you use phone 1 or phone 2 port?
07-03-2019 09:00 AM
Also want to mention, the ATA 190 Software Version: 1.2.2(003) Hardware Version: 1.1.1
07-03-2019 10:27 AM
Do you have these endpoints over the WAN or local to the CUCM network? I do see lot of software bugs related to unregistration for ATA190. Below are some for your reference:
CSCvp09761
CSCvk29369
07-03-2019 10:54 AM - edited 07-03-2019 10:57 AM
We have both WAN & local. I have not tried any other software versions. Is 1.2(2)SR1 newer than 1.2.2(003)?
Also, what is the procedure for upgrading the software?
07-03-2019 11:33 AM
Yes, 1.2(2)SR1 is newer version. You need to upload firmware files on CUCM TFTP servers and restart the TFTP Service. The ATA’s will download new firmware automatically.
07-03-2019 12:06 PM
07-03-2019 01:06 PM
Yes, you can upgrade it individually. You can follow below procedure which is applicable to ATA’s as well:
