Beginner
ATA 190 > Device Protocol SIP
I have a ton of ATA 190's in production on CUCM System version: 10.5.2.12901-1.
These devices constantly become unregistered and have to be reset before they will work again.
I use these for fax machines.
Any idea what causes this?
If you are only connecting one fax machine, does it matter if you use phone 1 or phone 2 port?
6 REPLIES 6
Highlighted
Beginner
Re: ATA 190 > Device Protocol SIP
Also want to mention, the ATA 190 Software Version: 1.2.2(003) Hardware Version: 1.1.1
Rising star
Do you have these endpoints over the WAN or local to the CUCM network? I do see lot of software bugs related to unregistration for ATA190. Below are some for your reference:
CSCvp09761
CSCvk29369
CSCut09456
CSCvi29663
Have you tried software version 1.2(2)SR1?
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
Beginner
We have both WAN & local. I have not tried any other software versions. Is 1.2(2)SR1 newer than 1.2.2(003)?
Also, what is the procedure for upgrading the software?
Rising star
Yes, 1.2(2)SR1 is newer version. You need to upload firmware files on CUCM TFTP servers and restart the TFTP Service. The ATA’s will download new firmware automatically.
Beginner
Is there a way to upgrade just one ATA so we can test before rolling it out to all in production?
Rising star
Yes, you can upgrade it individually. You can follow below procedure which is applicable to ATA’s as well:
https://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-callmanager/213288-upgrade-ip-phone-firmware-individually.html
Content for Community-Ad
July's Community Spotlight Awards
