Highlighted
Beginner
Re: Hi We are facing a strange
I resolve my blind transfer issue by going to option preference advance and change forward all call to no call.
cheers!!!!
Highlighted
Beginner
Hi, You may want to look at
You may want to look at your CTI Ports Locations and device pool as well, ensure that they are in the right DP and L which your phones are in.
Highlighted
Beginner
Re: Hi, You may want to look at
Thank you Tshepo, that resolved my problem.
Highlighted
Beginner
Hello all,
I encounter the same problem with CUEAC => from pstn call to operator, after blind transfer, just a notification to the final internal phone and no call.
The blind transfer works from internal phone to operator to final internal phone.
Unfortunately I don't see the key in regedit : Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Arc Solutions\Call Connect\Operator\Preferences\Default
Do I create this key? But there isn't path arc solutions...
Content for Community-Ad
FusionCharts will render here
