03-06-2014 06:05 PM - edited 03-19-2019 07:59 AM
I have a very simple beginner question I would've thought would be really easy to find the answer, but so far, I have not.
To set up a call system call handler for your basic company main number, do I need a physical phone with the number attached to a line.
I've tried it without the physical phone and can't get it to work, but with a line, no problem?
thanks
Solved! Go to Solution.
03-06-2014 06:51 PM
No, you can simply configure a CTI RP with CFA to VM, I'm assuming you're using CUCM.
03-07-2014 05:51 AM
Hi Mark,
Some people use the press * during a user greeting to access
their voicemail remotely
But as you nicely noted, a more common remote access
config would be to use a DID for your VM pilot number or at least route
a DID to your VM pilot number for easy access to the Sign-In
conversation.
Cheers!
Rob
"May your heart always be joyful
And may your song always be sung
May you stay forever young "
- Dylan
03-11-2014 05:39 AM
Hi Mark,
Sure, a CTI-RP is a perfect way to go about this. That is how our
remote DID is set up :)
Cheers!
Rob
03-06-2014 06:06 PM
sorry should've mentioned v. 8.6
03-06-2014 06:51 PM
03-06-2014 07:43 PM
Thank You.
Figured it would be fairly simple, just needed to know where to start.
This might be the answer to another beginner question I have been thinking about also.
Is it common for users to call their own number when they are calling in from outside to pick up vm and then press * to access?
The Meridian system we are tossing has a common DID number, but the way our vm was setup, the number is internal. I'm not sure if calling your own number is common or if I need to make a new number, or another CTI rp sort of thing and forward to internal vm DN.
Hope that makes sense.
03-07-2014 05:51 AM
Hi Mark,
conversation.
Cheers!
Rob
- Dylan
03-08-2014 05:58 PM
Thanks, would using a CTI rp, be the most efficient way of doing that?
03-11-2014 05:39 AM
Hi Mark,
Cheers!
Rob
