ANNOUNCEMENT - The community will be down for maintenace this Thursday August 13 from 12:00 AM PT to 02:00 AM PT. As a precaution save your work.
Highlighted
Rising star
Re: Blackberry MVS Installation
Alexander, are you 100% confident on this, as I'm getting info from multiple sources that MVS requires BES enterprise, although I don't trust those sources. Have you actually done it or know someone who did?
Highlighted
Hi Roman,
I'm not 100% for sure. But as I can see my BB getting registered with my UC500. So I would say that basicly you're able to get this config running.
As I'm not aware of using IOS I have the problem that I'm not able to configure my UC via command line and from this point don't have the possibility to verify this.
BTW, does anybody has this configured during the last weeks/month?
Best
Alex
Highlighted
Beginner
BES Express is not supported
Highlighted
Contributor
I reitereate that it is true that as of this posting, RIM does not "support" MVS in conjunction with BES Express,
That said, it does work.  I have successfully tested all MVS 5.0 builds (5.0.1 & MRs and 5.0.2 & MRs) against BES Express 5.0.2 and 5.0.3.  As long as you point the MVS installer at the BESX' SQL Express instance (besxhostname\BLACKBERRY, if left default) it will work exactly like an install against a BES Enterprise.
I wouldn't suggest this in the real world due to the lack of official vendor support, but for a customer demo lab or whatnot, BESX will do what you want it to.
-jd
Highlighted
Beginner
Beginner
How did you manage to add CALs via BESx BAS?
Highlighted
Beginner
Hey, anyone still have a
Hey, anyone still have a Blackberry MVS Server license? I can't seem to get my hands on one since it was discontinued.  Really wanted to give this a try.
Highlighted
Beginner
Adam, contact your RIM rep, there is an Integration Guide for CUCM now.
Highlighted
Hi Colin,
do you have this integration guide available? If so, would be great if you could share it with us.
Basically MVS is supported with BESX. Unfortunately the official support has been retired since the current MVS version. I'm not sure which release it was.
Actually the RIM supports the MVS only with BES but as jdiegmueller stated above it sill work (unsupported).
I would love to see my BB working with the UC500. Does anyone knows other ways to get this done?
Best Regards
Alex
