Highlighted
Beginner
Block incoming call on H.323 Gateway
Hi everyone
I have a number that I want to block on  one of our gateways and I wanted to know can someone look over my commands because I used my number as a test to see if it would work and I can still reach the office.
Voice translation rule to block a number
voice translation-rule 10
rule 1 reject /7606227654/
Apply the rule to a translation profile for the calling number
voice translation-profile call_block
translate calling 1
Include the translation profile within a dial peer definition
dial-peer voice 9001  pots
call-block translation-profile incoming call_block
Invoke the voice translation profile “call_block
call-block disconnect-cause incoming call-reject
incoming called-number 7606227654
direct-inward-dial
Match this peer for all inbound POTS calls
port 1/0:23
1 ACCEPTED SOLUTION
Highlighted
Participant
Ok you can check the config
Ok you can check the config posted by William Bell,
http://www.netcraftsmen.net/blogs/unifiedcommunications/entry/cisco-cucm-blocking-calls-by-calling-party-number-id.html
If you have a doubt please let me know.
Please rate useful information.
Regards.
11 REPLIES 11
Highlighted
Rising star
The configuration you list
The configuration you list looks right to me. Have you run any debugging to verify you're matching dial-peer 9001? You can use "debug ccapi inout" to see what dial-peer is getting matched.
-Jameson
-Jameson
Highlighted
Beginner
JamesonIf you have 2 GW at
Jameson
If you have 2 GW at the site would I have to place the rule on both GW, because I'm matching dial-peer 9001. I looked at what was active when I was on the call my number is the 2066 number I called them on and they are 2000
.Jul 28 19:27:16.693: %ISDN-6-CONNECT: Interface Serial1/0:3 is now connected to 8178412066 N/A
.Jul 28 19:27:17.025: %ISDN-6-CONNECT: Interface Serial1/0:3 is now connected to 8178412066 N/A
.Jul 28 19:27:17.029: %ISDN-6-DISCONNECT: Interface Serial1/0:2  disconnected from 2147161923 , call lasted 1364 seconds
CallID     CID  ccVdb      Port             DSP/Ch  Called #   Codec    Dial-peers
0x1E037E   3959 0x659757D4 1/0:23.1         1/7:1   2088       g711ulaw  9001/1001
0x1E0380   395A 0x659757D4 1/0:23.2         1/7:2   2411       g711ulaw  9001/1001
0x1E0384   395C 0x659757D4 1/0:23.4         1/7:4   2000       g711ulaw  9001/1001
Highlighted
Rising star
I see the issue... You're
I see the issue... You're translating the calling number that matches /7606227654/, and your incoming called-number is 7606227654. Unless you're calling from and to 7606227654, the call won't be blocked with this configuration.
If you want to block all calls to 7606227654, change "translate calling 1" to "translate called 1". If you want to block all calls from a specific number, instead change your reject rule to match the caller's number.
-Jameson
-Jameson
Highlighted
Beginner
JamesonThat's what I thought
Jameson
That's what I thought I had done, so would  you look at  this and tell me if this is correct becuase I want to block a person from calling the office.
rule 1 reject /5137013243/
translate calling 1
incoming called-number 5137013243
direct-inward-dial
port 1/0:23
Highlighted
Rising star
You've got everything except
You've got everything except the "incoming called-number" correct. I would leave "incoming called-number" as however you had it configured previous to your changes.
Don't confuse "called number" with "calling number". Here's a good example for you... Let's say my phone is 234-567-8910, and I'm calling your gateway at 760-622-7654. From your gateway's perspective, the "called number" would be 760-622-7654 (assuming the telco provides all 10 digits), and the "calling number" would be 234-567-8910.
-Jameson
-Jameson
Beginner
JamesonMy manager just told
Jameson
My manager just told me that the 9001 dial-peer is pots but it's for outbound calls only and that I should apply the rule to dial-peer 1001 which is voip. so when I do the command there is no port 1/0:23 to match the peer for inbound calls. so now how would I change the command work on a voip dial peer.
Eric
Highlighted
Participant
Hi scooter817,What´s your
Hi scooter817,
What´s your CUCM Version? blocking incoming calls on gateway is a bit stressful, you can block calls by calling party number from CUCM, this is very easy.
Let me know if you need anything else.
Regards.
Highlighted
Beginner
Hi EmmanuelI have a person
Hi Emmanuel
I have a person who is calling our office 713 547-4000  from 513 701-3242 and I want to block the 513 701-3242 from reaching our office.
Eric
Highlighted
Participant
Hi scooter817,
This config works from CUCM 8.x and later.
Regards.
Highlighted
Beginner
10.5.1
10.5.1
Highlighted
Participant
Regards.
