Call Forwarding From FXO
jkjackson
We currently have our 2811's setup with two or more pots lines for SRST and employee only call in lines. We had it so that any call comming in on the pots lines would get forwarded to an internal extension. I am trying to change the extension it is forwarding calls to but can't seem to get it to work.
I am going into call manager, locating the gateway, slecting the FXO port that i want to change and then changing the Attendant DN. However this doesn't do anything and the incomming calls still route to the old extension.
Thanks for the help
jk
thomuff
Level 3
Level 3
I believe it easier to make the change on the voice ports in the router. Using the connection plar command, for example,
voice-port 0/1/0
connection plar 51700
This would forward incoming call on POTS to phone with line 51700
Let me know if this helps
