12-07-2013 05:34 AM - edited 03-19-2019 07:37 AM
We have configured an auto attendant with an extension XXXX, and created an CTI route point with same extension.
we have an operator phone with extension YYYY, whenever Operator gets a call, if its not answered by Operator, the call should get forwarded to auto attendant extension XXXX, where it plays our customized greetings which is not happening.
Instead of playing auto attendant Greetings, it plays " Hello, cisco unity connection messaging system, from a text tone telephone you may dial an extension at any time"
Configuration CUCM -- SIP Trunk -- CUC and in CUC -- Port Group -- Integration Method SCC
MAC
Solved! Go to Solution.
12-07-2013 07:28 AM
Thats expected because CUC by default uses the original called number to route to a mailbox. Configure a VM profile to hardcode the DN you want, or use call routing rules in CUC
12-07-2013 07:28 AM
12-12-2013 11:47 PM
Hi Jaime,
I have used call routing rules in CUC and it worked well, thanks a ton
MAC
12-16-2013 02:02 AM
Hi Jaime,
After changes in CUC we have encountered an issue, it is effected to all the VOIP calls. For example, when i call any extension and if they are not picking the call it is going to Call Handler.
I wanted to configure it to for only to the Operator extension not to all.
CUC - Call Routing - Direct Forwarding - Send call To - Call Handler
Please let me know if i have configured it in right way
MAC
