09-21-2016 01:41 AM - edited 03-19-2019 11:36 AM
Recently we migrated the customer from 8.5 CUCM to 10.5 CUCM. After the migration we are observing that the caller id is not being displayed when the call comes from pstn >> to IP phone >> and picked via call pickup group.
Configuration wise it seems everything is similar. Not sure if it is a enterprise or service parameter that is affecting. Any suggestions .
Solved! Go to Solution.
09-24-2016 11:47 PM
Check this parameter if its set to false or true. Set it to false if its set to true and test
Aseem
09-24-2016 02:34 AM
can you share the following:
1. complete call flow
2. What kind of IP Phones you are using and their firmware?
3. What shows up on the caller ID when the call is answered via pickup?
4. What kind of pickup are you testing it with?
Aseem
09-24-2016 06:38 AM
pstn --> gateway --> Ipphone --> call picked by pressing call pick group or by clicking on the BLF.
Cisco IP phone 7975 cmterm-7975-sccp.9-4-2ES13-rel.k3.cop.sgn
forwarded for <display name>
call pickup group (normal)
09-24-2016 11:47 PM
Aseem
09-28-2016 02:23 AM
Hi Aseem ,
we tested this in Lab today and found this to resolve our issue.
Thank you .
09-28-2016 04:17 AM
Thank you for the update! Glad it helped you fix it.
Aseem
