can not make an external call with CuCM and H323 gateway
ntphong2702
Hi experts, i'm having an issue with CuCM and h323 Gateway. i'm using a 2811 router to make an H323 gateway, CuCM server and Switch layer 2 to build a VoIP LAB, this my network:
and my router configuration:
Current configuration : 2335 bytes
version 12.4
hostname Router
boot-start-marker
boot-end-marker
logging message-counter syslog
no aaa new-model
dot11 syslog
ip source-route
ip cef
ip dhcp excluded-address 192.168.1.1 192.168.1.10
ip dhcp pool VOICE
   network 192.168.1.0 255.255.255.0
   option 150 ip 192.168.1.2
   default-router 192.168.1.1
no ipv6 cef
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
fax protocol cisco
voice class h323 1
  h225 timeout tcp establish 3
voice translation-rule 1
rule 1 /^9/ //
voice translation-profile PSTN
translate called 1
voice-card 0
application
service aa1 flash:its-cisco.2.0.2.0.tcl
  paramspace english language en
  paramspace english index 1
  param aa-pilot 0839959204
  paramspace english location flash:
  paramspace english prefix en
archive
log config
  hidekeys
interface FastEthernet0/0
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip bind srcaddr 192.168.1.1
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
voice-port 0/0/0
echo-cancel coverage 32
connection plar opx 3100
description 08395959204
caller-id enable
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
dial-peer voice 1010 pots
service aa1
incoming called-number 08395959204
direct-inward-dial
port 0/0/0
dial-peer voice 2020 pots
description PSTN
translation-profile outgoing PSTN
destination-pattern 9T
progress_ind setup enable 3
progress_ind progress enable 8
port 0/0/0
forward-digits all
dial-peer voice 10 voip
destination-pattern 1...
voice-class h323 1
session target ipv4:192.168.1.2
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
line con 0
line aux 0
line vty 0 4
password cisco
login
scheduler allocate 20000 1000
end
i configured h323 Gateway and router parttern on CUCM follow attach files
what's problem and how to solve it?
thanks for all helping.
Jaime Valencia
Your DP pointing to CUCM is wrong, or your plar OPX, whichever you need.
voice-port 0/0/0
caller-id enable
voice-class h323 1
codec g711ulaw
no vad
Your DP expects 1... and you're sending 3100, they need to match.
You might need to change the significantt digits and inbound CSS, but that only you can know
For outbound, you're discarding predot 9, but yet, you're expecting it in your DP, again, change as you need to.
description PSTN
port 0/0/0
forward-digits all
You cannot forward digits all, you'll also send the 9 for every call
Adjust your configuration as you wish/need.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Jaime Valencia
voice-port 0/0/0
caller-id enable
voice-class h323 1
codec g711ulaw
no vad
description PSTN
port 0/0/0
forward-digits all
java
java
Thank you for your help. I will follow it
