configure & troubleshoot anyconnect
500
Beginner
CCX Finesse, Cannot hear during silent monitor
Hi All!
First, I am a new to the Cisco PBX world; please be gentle.
I have an issue where I cannot silent monitor through Finesse.  I show connected/monitoring, however no sound via the IP Communicator.
We're running :
CCX 10.6.1000000-39
CUCM 10.5.2.11900-3
IP Communicator 8.6.4.0
Verified the following:
Built in user bridge enabled
Call space correct
Agent skills verified
Agent enabled for call monitoring
Agent enabled for cti
Behavior Recognized:
Showing monitoring on IP Communicator
No audible sound
I have exhausted the scope of my minimal knowledge.  All my online recon is coming back with a similar scenario with CAD, although nothing for Finesse proper.
In the following discussion, https://supportforums.cisco.com/discussion/13014691/supervisor-can-silent-monitor-can-not-hear-agent , someone references SPAN configurations within CUCM associated with the user device, however I cannot seem to find these.
Any suggestions on what to do next?
Greatly Appreciated!
Dave
4 REPLIES 4
Beginner
Re: CCX Finesse, Cannot hear during silent monitor
I am having the same issue. How did you fix it?
Beginner
we also have the same problem, no errors given
Highlighted
VIP Collaborator
Hi there
Please try this
  • Check the windows firewall permissions.
  • Check the device name of CIPC. Make it in ALL CAPS
See that helps
Hope this Helps
Cheers
Rath!
***Please rate helpful posts***
Beginner
Hi Dave,
you would find the "SPAN to PC" port option only on (the agents) desk phones, eg. an 8841.
This option would allow the phone to forward/mirror packets from the phone port to the PC port.
If you are only using CIPC I guess there is no need for that.
Cheers,
Pier
