Certificate issues with Mobility Advantage
ronaldo.gama
In Mobility Advantage 7.x documentation´s, the supported Certificate Authorities are Verisign and GeoTrust.
The solution working with the GoDaddy certificates?
The installation procedure is the same?
Ronaldo Gama
Just a small information about cisco.
Alot of things that they say that is not supported are working fine, the only problem that in case you have a problem and you open a TAC case m they will kick the case out , so i always strongly recommends that you follow the SRND and the compatbility matrix (hardware and software) because in this case , cisco should help you in everyway they can.
Amer
