Beginner
CFWD goes busy, but regular call works
I am assisting with CME 7.0, the site users want to use CFWD, but the call either responds with fast busy or call can not be completed as dialed.  If I have the user dial the number directly it dials out and the call connects.
If they press CFWD on the phone and dial the same call that just completed, the call fails.  The regular call will hit the PRI with dial-peer 8, the CFWD skips dial-peer 8 and 19 then fails.  Hoping someone can spot something in the following debugs or has another idea as to why this occurs?
The following are from 'deb voice ccapi inout':
Regular call, connects:
Feb  5 04:04:59.305: //22126/7FD887CCBC96/CCAPI/ccCallSetupRequest:
   Calling Number=123(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=9######6403(TON=Unknown, NPI=Unknown),
   Redirect Number=, Display Info=SteveG
   Account Number=, Final Destination Flag=FALSE,
   Guid=7FD887CC-8D51-11E3-BC96-80330B61217B, Outgoing Dial-peer=8
Feb  5 04:04:59.305: //22126/7FD887CCBC96/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=123
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=9######6403
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
   cisco-redirectreason=0   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
Feb  5 04:04:59.305: //22126/7FD887CCBC96/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x4B82536C, Interface Type=6, Destination=, Mode=0x0,
   Call Params(Calling Number=123,(Calling Name=SteveG)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=A
llowed),
   Called Number=9######6403(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE, Outgoing Dial-peer=8, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Feb  5 04:04:59.305: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Feb  5 04:04:59.305: :cc_get_feature_vsa malloc success
Feb  5 04:04:59.305:  cc_get_feature_vsa count is 2
Feb  5 04:04:59.305: :FEATURE_VSA attributes are: feature_name:0,feature_time:1268693680,feature_id:44252
Feb  5 04:04:59.309: //22127/7FD887CCBC96/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
Feb  5 04:04:59.309: //22127/7FD887CCBC96/CCAPI/ccCallSetContext:
   Context=0x4BA085C0
Feb  5 04:04:59.309: //22126/7FD887CCBC96/CCAPI/ccSaveDialpeerTag:
chrs-phx-cme#
Feb  5 04:04:59.341: //22127/7FD887CCBC96/CCAPI/cc_api_call_proceeding:
   Interface=0x4B82536C, Progress Indication=NULL(0)
Feb  5 04:05:00.417: //22127/7FD887CCBC96/CCAPI/cc_api_call_cut_progress:
   Interface=0x4B82536C, Progress Indication=INBAND(8), Signal Indication=INTERCEPT(2),
   Cause Value=0
   Call Entry(Responsed=TRUE)
Feb  5 04:05:00.421: //22126/7FD887CCBC96/CCAPI/ccCallCutProgress:
   Progress Indication=INBAND(8), Signal Indication=INTERCEPT(2), Cause Value=0
   Voice Call Send Alert=FALSE, Call Entry(Alert Sent=FALSE)
Feb  5 04:05:00.421: //22126/7FD887CCBC96/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=Null,
   Tone Direction=Network, Params=0x0, Call Id=22126
Feb  5 04:05:00.421: //22126/7FD887CCBC96/CCAPI/ccConferenceCreate:
   (confID=0x4BACF6DC, callID1=0x566E, gcid=7FD887CC-8D5111E3-BC968033-B61217B, tag=0x0)
Feb  5 04:05:00.421: //22127/7FD887CCBC96/CCAPI/ccConferenceCreate:
   (confID=0x4BACF6DC, callID2=0x566F, gcid=7FD887CC-8D5111E3-BC968033-B61217B, tag=0x0)
   Conference Id=0x4BACF6DC, Call Id1=22126, Call Id2=22127, Tag=0x0
Feb  5 04:05:00.421: //22126/7FD887CCBC96/CCAPI/cc_api_bridge_done:
   Conference Id=0x1B47, Source Interface=0x4B3E529C, Source Call Id=22126,
   Destination Call Id=22127, Disposition=0x0, Tag=0xFFFFFFFF
Feb  5 04:05:00.421: //22127/7FD887CCBC96/CCAPI/cc_api_bridge_done:
   Conference Id=0x1B47, Source Interface=0x4B82536C, Source Call Id=22127,
   Destination Call Id=22126, Disposition=0x0, Tag=0xFFFFFFFF
Feb  5 04:05:00.421: //22126/7FD887CCBC96/CCAPI/cc_generic_bridge_done:
   Call Entry(Conference Id=0x1B47, Destination Call Id=22127)
   Call Entry(Conference Id=0x1B47, Destination Call Id=22126)
Feb  5 04:05:00.421: //22126/7FD887CCBC96/CCAPI/cc_api_caps_ind:
   Destination Interface=0x4B82536C, Destination Call Id=22127, Source Call Id=22126,
   Caps(Codec=0x1, Fax Rate=0x2, Vad=0x1,
   Modem=0x2, Codec Bytes=160, Signal Type=2)
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=1000(ms), Fax Nom=300(ms))
Feb  5 04:05:00.421: //22127/7FD887CCBC96/CCAPI/cc_api_caps_ind:
   Destination Interface=0x4B3E529C, Destination Call Id=22126, Source Call Id=22127,
   Caps(Codec=0x1, Fax Rate=0x1, Vad=0x1,
Feb  5 04:05:00.421: //22127/7FD887CCBC96/CCAPI/cc_api_caps_ack:
   Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=OFF(0x1),
   Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=9639)
Feb  5 04:05:00.421: //22126/7FD887CCBC96/CCAPI/cc_api_caps_ack:
   Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_NONE(0x1), Vad=OFF(0x1),
   Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=3197)
Feb  5 04:05:00.425: //22126/7FD887CCBC96/CCAPI/ccCallFeature:
   Feature Type=25, Call Id=22126
Feb  5 04:05:00.425: //22126/7FD887CCBC96/CCAPI/cc_api_voice_mode_event:
   Call Id=22126
   Call Entry(Context=0x4BA17620)
Feb  5 04:05:00.429: //22127/7FD887CCBC96/CCAPI/cc_api_voice_mode_event:
   Call Id=22127
chrs-phx-cme#
   Call Entry(Context=0x4BA085C0)
Feb  5 04:05:00.429: //22126/7FD887CCBC96/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x1B47, Call Id1=22126, Call Id2=22127
chrs-phx-cme#
Feb  5 04:05:04.633: //22126/7FD887CCBC96/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x4B3E529C, Call Id=22126
   Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
Feb  5 04:05:04.633: //22126/7FD887CCBC96/CCAPI/ccConferenceDestroy:
   Conference Id=0x1B47, Tag=0x0
Feb  5 04:05:04.633: //22126/7FD887CCBC96/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=22127, Disposition=0x0, Tag=0x0
Feb  5 04:05:04.633: //22127/7FD887CCBC96/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=22126, Disposition=0x0, Tag=0x0
Feb  5 04:05:04.633: //22126/7FD887CCBC96/CCAPI/cc_generic_bridge_done:
Feb  5 04:05:04.633: //22127/7FD887CCBC96/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
   Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Feb  5 04:05:04.633: //22127/7FD887CCBC96/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
Feb  5 04:05:04.637: //22126/7FD887CCBC96/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Feb  5 04:05:04.637: //22126/7FD887CCBC96/CCAPI/cc_api_get_transfer_info:
Feb  5 04:05:04.641: //22126/7FD887CCBC96/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x4B3E529C, Tag=0x0, Call Id=22126,
   Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
Feb  5 04:05:04.641: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Feb  5 04:05:04.641: :cc_free_feature_vsa freeing 4B9ED248
Feb  5 04:05:04.641:  vsacount in free is 1
Feb  5 04:05:04.681: //22127/7FD887CCBC96/CCAPI/cc_api_call_disconnect_done:
chrs-phx-cme#Disposition=0, Interface=0x4B82536C, Tag=0x0, Call Id=22127,
Feb  5 04:05:04.681: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Feb  5 04:05:04.681: :cc_free_feature_vsa freeing 4B9EBAA8
Feb  5 04:05:04.681:  vsacount in free is 0
phx-cme#
CFWD Call, fails (starts at dial-peer 8 and then dial-peer 19):
Feb  5 04:01:14.989: //22122/FCBFBDC6BC8C/CCAPI/ccCallSetupRequest:
   Calling Number=142(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=123(TON=Unknown, NPI=Unknown),
   Redirect Number=, Display Info=JRuddy
   Guid=FCBFBDC6-8D50-11E3-BC8C-80330B61217B, Outgoing Dial-peer=20011
Feb  5 04:01:14.989: //22122/FCBFBDC6BC8C/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=142
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=123
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
Feb  5 04:01:14.989: //22122/FCBFBDC6BC8C/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x4B3E529C, Interface Type=6, Destination=, Mode=0x0,
   Call Params(Calling Number=142,(Calling Name=JRuddy)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=A
llowed),
   Called Number=123(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE, Outgoing Dial-peer=20011, Call Count On=FALSE,
Feb  5 04:01:14.989: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Feb  5 04:01:14.989: :cc_get_feature_vsa malloc success
Feb  5 04:01:14.989:  cc_get_feature_vsa count is 2
Feb  5 04:01:14.989: :FEATURE_VSA attributes are: feature_name:0,feature_time:1268699728,feature_id:44242
Feb  5 04:01:14.989: //22123/FCBFBDC6BC8C/CCAPI/ccIFCallSetupRequestPrivate:
Feb  5 04:01:14.989: //22123/FCBFBDC6BC8C/CCAPI/ccCallSetContext:
   Context=0x4B9FF988
Feb  5 04:01:14.989: //22122/FCBFBDC6BC8C/CCAPI/ccSaveDialpeerTag:
Feb  5 04:01:14.993: //22123/FCBFBDC6BC8C/CCAPI/cc_api_update_call_info:
   Interface=0x4B3E529C, Call Id=0x566B
Feb  5 04:01:14.997: //22123/FCBFBDC6BC8C/CCAPI/cc_api_call_proceeding:
   Interface=0x4B3E529C, Progress Indication=NULL(0)
Feb  5 04:01:15.001: //22123/FCBFBDC6BC8C/CCAPI/cc_api_call_alert:
   Interface=0x4B3E529C, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
   Call Entry(Retry Count=0, Responsed=TRUE)
Feb  5 04:01:15.001: //22122/FCBFBDC6BC8C/CCAPI/ccCallAlert:
   Call Entry(Responsed=TRUE, Alert Sent=TRUE)
chrs-phx-cme#
Feb  5 04:01:15.001: //22122/FCBFBDC6BC8C/CCAPI/ccCallFeature:
   Feature Type=25, Call Id=22122
chrs-phx-cme#
Feb  5 04:01:25.001: //22123/FCBFBDC6BC8C/CCAPI/cc_api_call_disconnected:
   Cause Value=19, Interface=0x4B3E529C, Call Id=22123
   Call Entry(Responsed=TRUE, Cause Value=19, Retry Count=0)
Feb  5 04:01:25.001: //22122/FCBFBDC6BC8C/CCAPI/ccCallReleaseResources:
   release reserved xcoding resource.
Feb  5 04:01:25.001: //22123/FCBFBDC6BC8C/CCAPI/cc_api_get_transfer_info:
Feb  5 04:01:25.001: //-1/xxxxxxxxxxxx/CCAPI/ccUpdateRedirectingNumber:
   type=6 redirecting_number=123
Feb  5 04:01:25.001: //-1/xxxxxxxxxxxx/CCAPI/ccUpdateRedirectNumber:
   type=6  Original Called Number=123, Called Number=123, Calling Number=142, Calling DN=216 Calling Id=22122,
   Redirect Number=9###6403, Redirect Reason=2
Feb  5 04:01:25.001: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Feb  5 04:01:25.001: :cc_get_feature_vsa malloc success
Feb  5 04:01:25.001:  cc_get_feature_vsa count is 3
Feb  5 04:01:25.001: :FEATURE_VSA attributes are: feature_name:0,feature_time:1268693232,feature_id:44243
Feb  5 04:01:25.001: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
Feb  5 04:01:25.001:  feature_vsa is 4B9ED6A8,featname is 0
Feb  5 04:01:25.001:  cc_get_feature_vsa count is 4
Feb  5 04:01:25.001: :FEATURE_VSA attributes are: feature_name:0,feature_time:1268696592,feature_id:44244
Feb  5 04:01:25.001: : Generating new featurevsa,inserting it
Feb  5 04:01:25.001:  feature call forward featname is 3
Feb  5 04:01:25.001:  feature_vsa is 4B9ED248,featname is 0
Feb  5 04:01:25.001:  cc_get_feature_vsa count is 5
Feb  5 04:01:25.005: :FEATURE_VSA attributes are: feature_name:0,feature_time:1268693680,feature_id:44245
Feb  5 04:01:25.005: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
Feb  5 04:01:25.005: : Generating new featurevsa,inserting it
Feb  5 04:01:25.005:  feature call forward featname is 3
Feb  5 04:01:25.005: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Feb  5 04:01:25.005: :cc_free_feature_vsa freeing 4B9EB8E8
Feb  5 04:01:25.005:  vsacount in free is 4
Feb  5 04:01:25.005: //22122/FCBFBDC6BC8C/CCAPI/ccCallForwardTo:
   Call Forward Number=96025056403, Call Forward Cause Reason=2, Call Id=22122
Feb  5 04:01:25.005: //22122/FCBFBDC6BC8C/CCAPI/ccGenerateToneInfo:
   Tone Direction=Network, Params=0x0, Call Id=22122
Feb  5 04:01:25.005: //22123/FCBFBDC6BC8C/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=19)
   Cause Value=19, Call Entry(Responsed=TRUE, Cause Value=19)
Feb  5 04:01:25.005: //22123/FCBFBDC6BC8C/CCAPI/cc_api_get_transfer_info:
Feb  5 04:01:25.009: //22123/FCBFBDC6BC8C/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x4B3E529C, Tag=0x0, Call Id=22123,
   Call Entry(Disconnect Cause=19, Voice Class Cause Code=0, Retry Count=0)
Feb  5 04:01:25.013: //22123/FCBFBDC6BC8C/CCAPI/cc_api_call_disconnect_done:
Feb  5 04:01:25.013: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Feb  5 04:01:25.013: :cc_free_feature_vsa freeing 4B9EBAA8
Feb  5 04:01:25.013:  vsacount in free is 3
Feb  5 04:01:25.013:  vsacount in free is 2
Feb  5 04:01:25.013: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Feb  5 04:01:25.013: :cc_get_feature_vsa malloc success
Feb  5 04:01:25.013:  cc_get_feature_vsa count is 3
Feb  5 04:01:25.013: :FEATURE_VSA attributes are: feature_name:0,feature_time:1268699728,feature_id:44246
Feb  5 04:01:25.013: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
Feb  5 04:01:25.013:  feature call forward featname is 3
Feb  5 04:01:25.013: :cc_free_feature_vsa freeing 4B9ED248
Feb  5 04:01:25.017: //22122/FCBFBDC6BC8C/CCAPI/ccCallForwardTo:
Feb  5 04:01:25.017: //22122/FCBFBDC6BC8C/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=8, Params=0x4BA021E8, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
Feb  5 04:01:25.017: //22122/FCBFBDC6BC8C/CCAPI/ccCheckClipClir:
   In: Calling Number=142(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Out: Calling Number=142(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Destination Pattern=9T, Called Number=96025056403, Digit Strip=TRUE
   Called Number=96025056403(TON=Unknown, NPI=Unknown),
   Redirect Number=123, Display Info=JRuddy
   Guid=03FF379D-8D51-11E3-BC91-80330B61217B, Outgoing Dial-peer=8
Feb  5 04:01:25.017: //22122/FCBFBDC6BC8C/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=142
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=9###6403
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=73
   cisco-rdn=123
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
   cisco-redirectreason=2   fwd_final_type =0
Feb  5 04:01:25.017: //22122/FCBFBDC6BC8C/CCAPI/ccIFCallSetupRequestPrivate:
llowed),
   Called Number=9###6403(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Feb  5 04:01:25.017: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Feb  5 04:01:25.017: :cc_get_feature_vsa malloc success
Feb  5 04:01:25.021:  cc_get_feature_vsa count is 3
Feb  5 04:01:25.021: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Feb  5 04:01:25.021: :FEATURE_VSA attributes are: feature_name:0,feature_time:1268699728,feature_id:44247
Feb  5 04:01:25.021: //22124/FCBFBDC6BC8C/CCAPI/ccIFCallSetupRequestPrivate:
Feb  5 04:01:25.021: //22124/FCBFBDC6BC8C/CCAPI/ccCallSetContext:
   Context=0x4BA02198
Feb  5 04:01:25.021: //22122/FCBFBDC6BC8C/CCAPI/ccSaveDialpeerTag:
Feb  5 04:01:25.021: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
Feb  5 04:01:25.021:  feature call forward featname is 3
Feb  5 04:01:25.021:  feature_vsa is 4B9ED248,featname is 0
Feb  5 04:01:25.021: :cc_get_feature_vsa malloc success
Feb  5 04:01:25.021:  cc_get_feature_vsa count is 4
Feb  5 04:01:25.021: :FEATURE_VSA attributes are: feature_name:0,feature_time:1268693680,feature_id:44248
chrs-phx-cme#
Feb  5 04:01:25.021: : Generating new featurevsa,inserting it
Feb  5 04:01:25.045: //22124/FCBFBDC6BC8C/CCAPI/cc_api_call_proceeding:
Feb  5 04:01:25.141: //22124/FCBFBDC6BC8C/CCAPI/cc_api_call_cut_progress:
   Cause Value=0
Feb  5 04:01:25.145: //22122/FCBFBDC6BC8C/CCAPI/ccCallCutProgress:
   Voice Call Send Alert=FALSE, Call Entry(Alert Sent=TRUE)
Feb  5 04:01:25.145: //22122/FCBFBDC6BC8C/CCAPI/ccGenerateToneInfo:
Feb  5 04:01:25.145: //22122/FCBFBDC6BC8C/CCAPI/ccConferenceCreate:
   (confID=0x4BACF64C, callID1=0x566A, gcid=FCBFBDC6-8D5011E3-BC8C8033-B61217B, tag=0x0)
Feb  5 04:01:25.145: //22124/FCBFBDC6BC8C/CCAPI/ccConferenceCreate:
   (confID=0x4BACF64C, callID2=0x566C, gcid=FCBFBDC6-8D5011E3-BC8C8033-B61217B, tag=0x0)
   Conference Id=0x4BACF64C, Call Id1=22122, Call Id2=22124, Tag=0x0
Feb  5 04:01:25.145: //22122/FCBFBDC6BC8C/CCAPI/cc_api_bridge_done:
   Conference Id=0x1B45, Source Interface=0x4B4ABC14, Source Call Id=22122,
   Destination Call Id=22124, Disposition=0x0, Tag=0xFFFFFFFF
Feb  5 04:01:25.145: //22124/FCBFBDC6BC8C/CCAPI/cc_api_bridge_done:
   Conference Id=0x1B45, Source Interface=0x4B82536C, Source Call Id=22124,
   Destination Call Id=22122, Disposition=0x0, Tag=0xFFFFFFFF
Feb  5 04:01:25.145: //22122/FCBFBDC6BC8C/CCAPI/cc_generic_bridge_done:
   Call Entry(Conference Id=0x1B45, Destination Call Id=22124)
   Call Entry(Conference Id=0x1B45, Destination Call Id=22122)
Feb  5 04:01:25.145: //22122/FCBFBDC6BC8C/CCAPI/cc_api_caps_ind:
   Destination Interface=0x4B82536C, Destination Call Id=22124, Source Call Id=22122,
Feb  5 04:01:25.145: //22124/FCBFBDC6BC8C/CCAPI/cc_api_caps_ind:
   Destination Interface=0x4B4ABC14, Destination Call Id=22122, Source Call Id=22124,
Feb  5 04:01:25.149: //22124/FCBFBDC6BC8C/CCAPI/cc_api_caps_ack:
   Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=7794)
Feb  5 04:01:25.149: //22122/FCBFBDC6BC8C/CCAPI/cc_api_caps_ack:
   Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=2870)
Feb  5 04:01:25.149: //22122/FCBFBDC6BC8C/CCAPI/ccCallFeature:
Feb  5 04:01:25.149: //22122/FCBFBDC6BC8C/CCAPI/cc_api_voice_mode_event:
   Call Id=22122
Feb  5 04:01:25.153: //22122/FCBFBDC6BC8C/CCAPI/cc_api_voice_mode_event:
   Call Entry(Context=0x4BA16218)
Feb  5 04:01:25.153: //22124/FCBFBDC6BC8C/CCAPI/cc_api_voice_mode_event:
   Call Id=22124
chrs-phx-cme#
   Call Entry(Context=0x4BA02198)
Feb  5 04:01:25.153: //22122/FCBFBDC6BC8C/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x1B45, Call Id1=22122, Call Id2=22124
chrs-phx-cme#
Feb  5 04:01:35.585: //22124/FCBFBDC6BC8C/CCAPI/cc_api_call_disconnected:
   Cause Value=18, Interface=0x4B82536C, Call Id=22124
   Call Entry(Responsed=TRUE, Cause Value=18, Retry Count=0)
Feb  5 04:01:35.585: //22122/FCBFBDC6BC8C/CCAPI/ccCallReleaseResources:
Feb  5 04:01:35.585: //22124/FCBFBDC6BC8C/CCAPI/ccCallSetAAA_Accounting:
   Accounting=1, Call Id=22124
Feb  5 04:01:35.585: //22122/FCBFBDC6BC8C/CCAPI/ccConferenceDestroy:
   Conference Id=0x1B45, Tag=0x0
Feb  5 04:01:35.589: //22122/FCBFBDC6BC8C/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=22124, Disposition=0x0, Tag=0x0
Feb  5 04:01:35.589: //22124/FCBFBDC6BC8C/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=22122, Disposition=0x0, Tag=0x0
Feb  5 04:01:35.589: //22122/FCBFBDC6BC8C/CCAPI/cc_generic_bridge_done:
Feb  5 04:01:35.589: //22124/FCBFBDC6BC8C/CCAPI/ccCallDisconnect:
   Cause Value=18, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=18)
   Cause Value=18, Call Entry(Responsed=TRUE, Cause Value=18)
Feb  5 04:01:35.589: //22124/FCBFBDC6BC8C/CCAPI/cc_api_get_transfer_info:
Feb  5 04:01:35.589: //22122/FCBFBDC6BC8C/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=Ring Back,
Feb  5 04:01:35.605: //22124/FCBFBDC6BC8C/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x4B82536C, Tag=0x0, Call Id=22124,
   Call Entry(Disconnect Cause=18, Voice Class Cause Code=0, Retry Count=0)
Feb  5 04:01:35.605: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Feb  5 04:01:35.605: :cc_free_feature_vsa freeing 4B9EBAA8
Feb  5 04:01:35.605:  vsacount in free is 3
Feb  5 04:01:35.605:  vsacount in free is 2
Feb  5 04:01:35.609: //22122/FCBFBDC6BC8C/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=19, Params=0x4BA07208, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
Feb  5 04:01:35.609: //22122/FCBFBDC6BC8C/CCAPI/ccCheckClipClir:
   Guid=03FF379D-8D51-11E3-BC91-80330B61217B, Outgoing Dial-peer=19
Feb  5 04:01:35.609: //22122/FCBFBDC6BC8C/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=142
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=9###6403
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=73
   cisco-rdn=123
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
Feb  5 04:01:35.609: //22122/FCBFBDC6BC8C/CCAPI/ccIFCallSetupRequestPrivate:
llowed),
   Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE, Outgoing Dial-peer=19, Call Count On=FALSE,
Feb  5 04:01:35.609: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Feb  5 04:01:35.609: :cc_get_feature_vsa malloc success
Feb  5 04:01:35.609:  cc_get_feature_vsa count is 3
Feb  5 04:01:35.609: :FEATURE_VSA attributes are: feature_name:0,feature_time:1268699728,feature_id:44249
Feb  5 04:01:35.613: //22125/FCBFBDC6BC8C/CCAPI/ccIFCallSetupRequestPrivate:
Feb  5 04:01:35.613: //22125/FCBFBDC6BC8C/CCAPI/ccCallSetContext:
   Context=0x4BA071B8
Feb  5 04:01:35.613: //22122/FCBFBDC6BC8C/CCAPI/ccSaveDialpeerTag:
Feb  5 04:01:35.613: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
Feb  5 04:01:35.613:  feature call forward featname is 3
Feb  5 04:01:35.613:  feature_vsa is 4B9ED248,featname is 0
Feb  5 04:01:35.613: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Feb  5 04:01:35.613: :cc_get_feature_vsa malloc success
Feb  5 04:01:35.613:  cc_get_feature_vsa count is 4
Feb  5 04:01:35.613: :FEATURE_VSA attributes are: feature_name:0,feature_time:1268693680,feature_id:44250
Feb  5 04:01:35.613: : Generating new featurevsa,inserting it
Feb  5 04:01:35.645: //22125/FCBFBDC6BC8C/CCAPI/cc_api_call_proceeding:
Feb  5 04:01:35.745: //22125/FCBFBDC6BC8C/CCAPI/cc_api_call_cut_progress:
   Cause Value=0
Feb  5 04:01:35.745: //22122/FCBFBDC6BC8C/CCAPI/ccCallCutProgress:
Feb  5 04:01:35.745: //22122/FCBFBDC6BC8C/CCAPI/ccGenerateToneInfo:
Feb  5 04:01:35.745: //22122/FCBFBDC6BC8C/CCAPI/ccConferenceCreate:
   (confID=0x4BACF4E4, callID1=0x566A, gcid=FCBFBDC6-8D5011E3-BC8C8033-B61217B, tag=0x0)
Feb  5 04:01:35.745: //22125/FCBFBDC6BC8C/CCAPI/ccConferenceCreate:
   (confID=0x4BACF4E4, callID2=0x566D, gcid=FCBFBDC6-8D5011E3-BC8C8033-B61217B, tag=0x0)
   Conference Id=0x4BACF4E4, Call Id1=22122, Call Id2=22125, Tag=0x0
Feb  5 04:01:35.745: //22122/FCBFBDC6BC8C/CCAPI/cc_api_bridge_done:
   Conference Id=0x1B46, Source Interface=0x4B4ABC14, Source Call Id=22122,
   Destination Call Id=22125, Disposition=0x0, Tag=0xFFFFFFFF
Feb  5 04:01:35.745: //22125/FCBFBDC6BC8C/CCAPI/cc_api_bridge_done:
   Conference Id=0x1B46, Source Interface=0x4B82536C, Source Call Id=22125,
Feb  5 04:01:35.745: //22122/FCBFBDC6BC8C/CCAPI/cc_generic_bridge_done:
   Call Entry(Conference Id=0x1B46, Destination Call Id=22125)
   Call Entry(Conference Id=0x1B46, Destination Call Id=22122)
Feb  5 04:01:35.745: //22122/FCBFBDC6BC8C/CCAPI/cc_api_caps_ind:
   Destination Interface=0x4B82536C, Destination Call Id=22125, Source Call Id=22122,
Feb  5 04:01:35.749: //22122/FCBFBDC6BC8C/CCAPI/cc_api_caps_ind:
Feb  5 04:01:35.749: //22125/FCBFBDC6BC8C/CCAPI/cc_api_caps_ind:
   Destination Interface=0x4B4ABC14, Destination Call Id=22122, Source Call Id=22125,
Feb  5 04:01:35.749: //22125/FCBFBDC6BC8C/CCAPI/cc_api_caps_ack:
   Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=81)
Feb  5 04:01:35.749: //22122/FCBFBDC6BC8C/CCAPI/cc_api_caps_ack:
   Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=4431)
Feb  5 04:01:35.749: //22122/FCBFBDC6BC8C/CCAPI/ccCallFeature:
Feb  5 04:01:35.753: //22122/FCBFBDC6BC8C/CCAPI/cc_api_voice_mode_event:
   Call Id=22122
Feb  5 04:01:35.753: //22125/FCBFBDC6BC8C/CCAPI/cc_api_voice_mode_event:
   Call Id=22125
chrs-phx-cme#
   Call Entry(Context=0x4BA071B8)
Feb  5 04:01:35.753: //22122/FCBFBDC6BC8C/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x1B46, Call Id1=22122, Call Id2=22125
chrs-phx-cme#
Feb  5 04:01:39.145: //22122/FCBFBDC6BC8C/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x4B4ABC14, Call Id=22122
Feb  5 04:01:39.145: //22122/FCBFBDC6BC8C/CCAPI/ccConferenceDestroy:
   Conference Id=0x1B46, Tag=0x0
Feb  5 04:01:39.145: //22122/FCBFBDC6BC8C/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=22125, Disposition=0x0, Tag=0x0
Feb  5 04:01:39.145: //22125/FCBFBDC6BC8C/CCAPI/cc_api_bridge_drop_done:
Feb  5 04:01:39.145: //22122/FCBFBDC6BC8C/CCAPI/cc_generic_bridge_done:
Feb  5 04:01:39.145: //22125/FCBFBDC6BC8C/CCAPI/ccCallDisconnect:
Feb  5 04:01:39.145: //22125/FCBFBDC6BC8C/CCAPI/cc_api_get_transfer_info:
Feb  5 04:01:39.149: //22122/FCBFBDC6BC8C/CCAPI/ccCallDisconnect:
Feb  5 04:01:39.149: //22122/FCBFBDC6BC8C/CCAPI/cc_api_get_transfer_info:
Feb  5 04:01:39.153: //22122/FCBFBDC6BC8C/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x4B4ABC14, Tag=0x0, Call Id=22122,
Feb  5 04:01:39.153: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Feb  5 04:01:39.153: :cc_free_feature_vsa freeing 4B9EC608
Feb  5 04:01:39.153:  vsacount in free is 3
Feb  5 04:01:39.153:  vsacount in free is 2
Feb  5 04:01:39.185: //22125/FCBFBDC6BC8C/CCAPI/cc_api_call_disconnect_done:
chrs-phx-cme#Disposition=0, Interface=0x4B82536C, Tag=0x0, Call Id=22125,
Feb  5 04:01:39.185: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Feb  5 04:01:39.185: :cc_free_feature_vsa freeing 4B9EBAA8
Feb  5 04:01:39.185:  vsacount in free is 1
Feb  5 04:01:39.185:  vsacount in free is 0
chrs-phx-cme#
8 REPLIES 8
Enthusiast
Hi Jason,
Can you please share "debug isdn q931" and "debug voice ccapi inout" & "debug voice dialpeer" separately for the failed call.
Nishant Savalia
Regards, Nishant Savalia
Beginner
Nishant,
    Console logging: disabled
    Monitor logging: disabled
    Buffer logging:  level debugging, 617 messages logged, xml disabled,
                    filtering disabled
    Exception Logging: size (4096 bytes)
    Count and timestamp logging messages: disabled
    Persistent logging: disabled
    Trap logging: level informational, 610 message lines logged
--More--
Log Buffer (300000 bytes):
Feb 14 01:03:42.644: ISDN Se0/3/0:23 Q931: Applying typeplan for sw-type 0xD is 0x0 0x0, Calling num 142
Feb 14 01:03:42.644: ISDN Se0/3/0:23 Q931: Sending SETUP  callref = 0x00EF callID = 0x8070 switch = primary-ni interface
= User
Feb 14 01:03:42.644: ISDN Se0/3/0:23 Q931: TX -> SETUP pd = 8  callref = 0x00EF
    Bearer Capability i = 0x8090A2
        Standard = CCITT
        Transfer Capability = Speech
        Transfer Mode = Circuit
        Transfer Rate = 64 kbit/s
    Channel ID i = 0xA9838A
        Exclusive, Channel 10
    Progress Ind i = 0x8183 - Origination address is non-ISDN
    Calling Party Number i = 0x0080, '142'
        Plan:Unknown, Type:Unknown
    Called Party Number i = 0xA1, '602XXXX03'
        Plan:ISDN, Type:National
    Redirecting Number i = 0x00008F, '123'
Feb 14 01:03:42.676: ISDN Se0/3/0:23 Q931: RX <- CALL_PROC pd = 8  callref = 0x80EF
Feb 14 01:03:42.776: ISDN Se0/3/0:23 Q931: RX <- PROGRESS pd = 8  callref = 0x80EF
    Progress Ind i = 0x8288 - In-band info or appropriate now available
Feb 14 01:03:47.696: ISDN Se0/3/0:23 Q931: TX -> DISCONNECT pd = 8  callref = 0x00EF
    Cause i = 0x8090 - Normal call clearing
Feb 14 01:03:47.716: ISDN Se0/3/0:23 Q931: RX <- RELEASE pd = 8  callref = 0x80EF
--More--                           Feb 14 01:03:47.716: ISDN Se0/3/0:23 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x00EF
chrs-phx-cme#
chrs-phx-cme#
chrs-phx-cme#u all
All possible debugging has been turned off
chrs-phx-cme#
chrs-phx-cme#cle logg
Clear logging buffer [confirm]
chrs-phx-cme#
chrs-phx-cme#
chrs-phx-cme#debug voice ccapi inout
voip ccapi inout debugging is on
chrs-phx-cme#sh          term len 0
chrs-phx-cme#sh logg
Syslog logging: enabled (0 messages dropped, 10 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering di
sabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
    Buffer logging:  level debugging, 910 messages logged, xml disabled,
                    filtering disabled
Feb 14 01:04:24.280: //-1/C74292F49068/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=
   cisco-ani=142
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
Feb 14 01:04:24.280: //-1/C74292F49068/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x4B53AD64, Call Info(
   Calling Number=142,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE,
   Incoming Dial-peer=20027, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Feb 14 01:04:24.280: //-1/C74292F49068/CCAPI/ccCheckClipClir:
Feb 14 01:04:24.280: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Feb 14 01:04:24.280: :cc_get_feature_vsa malloc success
Feb 14 01:04:24.280:  cc_get_feature_vsa count is 3
Feb 14 01:04:24.280: :FEATURE_VSA attributes are: feature_name:0,feature_time:1205170384,feature_id:2681
Feb 14 01:04:24.280: //1486/C74292F49068/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=142(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=(TON=Unknown, NPI=Unknown))
Feb 14 01:04:24.284: //1486/C74292F49068/CCAPI/cc_process_call_setup_ind:
   Event=0x4943C8E0
Feb 14 01:04:24.284: //1486/C74292F49068/CCAPI/ccCallSetContext:
   Context=0x47D7EC18
   >>>>CCAPI handed cid 1486 with tag 20027 to app "_ManagedAppProcess_Default"
Feb 14 01:04:24.284: //1486/C74292F49068/CCAPI/ccCallSetupAck:
   Call Id=1486
Feb 14 01:04:24.284: //1486/C74292F49068/CCAPI/cc_api_set_transfer_info:
   Transfer Number=, Transfer Reason=0x0
Feb 14 01:04:24.284: //1486/C74292F49068/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=TRUE, Tone=Dial Tone,
   Tone Direction=Network, Params=0x0, Call Id=1486
Feb 14 01:04:24.284: //1486/C74292F49068/CCAPI/ccSetDigitTimeouts:
   Initial Digit Timeout=-1000(ms), Inter Digit Timeout=-1000(ms)
   Call Entry(Inter Digit Timeout=10000(ms), Initial Digit Timeout=10000(ms))
Feb 14 01:04:24.284: //1486/C74292F49068/CCAPI/ccCallReportDigits:
   (callID=0x5CE, digit_event=0x1, enable=TRUE, consume=FALSE)
   Enabled=TRUE, Call Id=1486
Feb 14 01:04:24.284: //1486/C74292F49068/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x4B53AD64, callID=0x5CE, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
   Enabled=TRUE, Disposition=0x0, Interface=0x4B53AD64, Call Id=1486
   Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=5000(ms))
Feb 14 01:04:25.280: //1486/C74292F49068/CCAPI/cc_api_call_digit_begin:
   Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
   Source Call Id=1486, Digit=1, DigitBeginFlags=0x0,
   Rtp Timestamp=0x130718, Rtp Expiration=0x0
Feb 14 01:04:25.280: //1486/C74292F49068/CCAPI/cc_api_call_digit_end:
   Source Call Id=1486, Digit=1, Duration=100,
   Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
   Call Entry(Handoff Depth=0)
Feb 14 01:04:25.568: //1486/C74292F49068/CCAPI/cc_api_call_digit_begin:
   Source Call Id=1486, Digit=2, DigitBeginFlags=0x0,
   Rtp Timestamp=0x138418, Rtp Expiration=0x0
Feb 14 01:04:25.568: //1486/C74292F49068/CCAPI/cc_api_call_digit_end:
   Source Call Id=1486, Digit=2, Duration=100,
Feb 14 01:04:25.832: //1486/C74292F49068/CCAPI/cc_api_call_digit_begin:
   Source Call Id=1486, Digit=3, DigitBeginFlags=0x0,
   Rtp Timestamp=0x140118, Rtp Expiration=0x0
Feb 14 01:04:25.832: //1486/C74292F49068/CCAPI/cc_api_call_digit_end:
   Source Call Id=1486, Digit=3, Duration=100,
Feb 14 01:04:25.832: //1486/C74292F49068/CCAPI/ccCallReportDigits:
   (callID=0x5CE, digit_event=0x0, enable=FALSE, consume=FALSE)
Feb 14 01:04:25.832: //1486/C74292F49068/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x4B53AD64, callID=0x5CE, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
Feb 14 01:04:25.836: //1486/C74292F49068/CCAPI/ccCallProceeding:
Feb 14 01:04:25.836: //-1/xxxxxxxxxxxx/CCAPI/ccUpdateRedirectingNumber:
Feb 14 01:04:25.836: //-1/xxxxxxxxxxxx/CCAPI/ccUpdateRedirectNumber:
   type=6  Original Called Number=123, Called Number=123, Calling Number=142, Calling DN=216 Calling Id=1486,
   Redirect Number=9602XXXX03, Redirect Reason=15
Feb 14 01:04:25.840: //-1/xxxxxxxxxxxx/CCAPI/ccUpdateRedirectingNumber:
Feb 14 01:04:25.840: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Feb 14 01:04:25.840: :cc_get_feature_vsa malloc success
Feb 14 01:04:25.840:  cc_get_feature_vsa count is 4
Feb 14 01:04:25.840: :FEATURE_VSA attributes are: feature_name:0,feature_time:1205168592,feature_id:2682
Feb 14 01:04:25.840: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
Feb 14 01:04:25.840:  feature_vsa is 47D570C8,featname is 0
Feb 14 01:04:25.840:  cc_get_feature_vsa count is 5
Feb 14 01:04:25.840: :FEATURE_VSA attributes are: feature_name:0,feature_time:1205166576,feature_id:2683
Feb 14 01:04:25.840: : Generating new featurevsa,inserting it
Feb 14 01:04:25.840:  feature call forward featname is 1
Feb 14 01:04:25.840: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Feb 14 01:04:25.840: :cc_free_feature_vsa freeing 47D569C8
Feb 14 01:04:25.840:  vsacount in free is 4
Feb 14 01:04:25.840: //1486/C74292F49068/CCAPI/ccCallForwardTo:
   Call Forward Number=9602XXXX03, Call Forward Cause Reason=15, Call Id=1486
Feb 14 01:04:25.844:  cc_get_feature_vsa count is 5
Feb 14 01:04:25.844: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Feb 14 01:04:25.844: :FEATURE_VSA attributes are: feature_name:0,feature_time:1205168592,feature_id:2684
Feb 14 01:04:25.844: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
Feb 14 01:04:25.844:  feature call forward featname is 1
Feb 14 01:04:25.844: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Feb 14 01:04:25.844: :cc_free_feature_vsa freeing 47D569C8
Feb 14 01:04:25.844:  vsacount in free is 4
Feb 14 01:04:25.844: //1486/C74292F49068/CCAPI/ccCallForwardTo:
Feb 14 01:04:25.848: //1486/C74292F49068/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=8, Params=0x47D6FC08, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
Feb 14 01:04:25.848: //1486/C74292F49068/CCAPI/ccCheckClipClir:
   Destination Pattern=9T, Called Number=9602XXXX03, Digit Strip=TRUE
   Called Number=9602XXXX03(TON=Unknown, NPI=Unknown),
   Guid=C831D423-944A-11E3-906C-ECFAA818FF8E, Outgoing Dial-peer=8
Feb 14 01:04:25.848: //1486/C74292F49068/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=142
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=9602XXXX03
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=73
   cisco-rdn=123
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
   cisco-redirectreason=15   fwd_final_type =0
Feb 14 01:04:25.848: //1486/C74292F49068/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x4A0C1364, Interface Type=6, Destination=, Mode=0x0,
llowed),
   Called Number=9602XXXX03(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Feb 14 01:04:25.848: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Feb 14 01:04:25.848: :cc_get_feature_vsa malloc success
Feb 14 01:04:25.848:  cc_get_feature_vsa count is 5
Feb 14 01:04:25.848: :FEATURE_VSA attributes are: feature_name:0,feature_time:1205168592,feature_id:2685
Feb 14 01:04:25.848: //1487/C74292F49068/CCAPI/ccIFCallSetupRequestPrivate:
Feb 14 01:04:25.848: //1487/C74292F49068/CCAPI/ccCallSetContext:
   Context=0x47D6FBB8
Feb 14 01:04:25.848: //1486/C74292F49068/CCAPI/ccSaveDialpeerTag:
Feb 14 01:04:25.848: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
Feb 14 01:04:25.848:  feature call forward featname is 1
Feb 14 01:04:25.848:  feature_vsa is 47D569C8,featname is 0
Feb 14 01:04:25.848:  cc_get_feature_vsa count is 6
Feb 14 01:04:25.848: :FEATURE_VSA attributes are: feature_name:0,feature_time:1205167248,feature_id:2686
Feb 14 01:04:25.848: : Generating new featurevsa,inserting it
Feb 14 01:04:25.880: //1487/C74292F49068/CCAPI/cc_api_call_proceeding:
   Interface=0x4A0C1364, Progress Indication=NULL(0)
Feb 14 01:04:25.980: //1487/C74292F49068/CCAPI/cc_api_call_cut_progress:
   Interface=0x4A0C1364, Progress Indication=INBAND(8), Signal Indication=INTERCEPT(2),
   Cause Value=0
Feb 14 01:04:25.980: //1486/C74292F49068/CCAPI/ccCallCutProgress:
Feb 14 01:04:25.980: //1486/C74292F49068/CCAPI/ccGenerateToneInfo:
Feb 14 01:04:25.980: //1486/C74292F49068/CCAPI/ccConferenceCreate:
   (confID=0x4BCAA234, callID1=0x5CE, gcid=C74292F4-944A11E3-9068ECFA-A818FF8E, tag=0x0)
Feb 14 01:04:25.980: //1487/C74292F49068/CCAPI/ccConferenceCreate:
   (confID=0x4BCAA234, callID2=0x5CF, gcid=C74292F4-944A11E3-9068ECFA-A818FF8E, tag=0x0)
   Conference Id=0x4BCAA234, Call Id1=1486, Call Id2=1487, Tag=0x0
Feb 14 01:04:25.980: //1486/C74292F49068/CCAPI/cc_api_bridge_done:
   Conference Id=0x1AC, Source Interface=0x4B53AD64, Source Call Id=1486,
   Destination Call Id=1487, Disposition=0x0, Tag=0xFFFFFFFF
Feb 14 01:04:25.984: //1487/C74292F49068/CCAPI/cc_api_bridge_done:
   Conference Id=0x1AC, Source Interface=0x4A0C1364, Source Call Id=1487,
   Destination Call Id=1486, Disposition=0x0, Tag=0xFFFFFFFF
Feb 14 01:04:25.984: //1486/C74292F49068/CCAPI/cc_generic_bridge_done:
Feb 14 01:04:25.984: //1486/C74292F49068/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x1AC, Destination Call Id=1487)
Feb 14 01:04:25.984: //1487/C74292F49068/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x1AC, Destination Call Id=1486)
Feb 14 01:04:25.984: //1486/C74292F49068/CCAPI/cc_api_caps_ind:
   Destination Interface=0x4A0C1364, Destination Call Id=1487, Source Call Id=1486,
Feb 14 01:04:25.984: //1487/C74292F49068/CCAPI/cc_api_caps_ind:
   Destination Interface=0x4B53AD64, Destination Call Id=1486, Source Call Id=1487,
Feb 14 01:04:25.984: //1487/C74292F49068/CCAPI/cc_api_caps_ack:
   Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=5173)
Feb 14 01:04:25.984: //1486/C74292F49068/CCAPI/cc_api_caps_ack:
   Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=5156)
Feb 14 01:04:25.988: //1486/C74292F49068/CCAPI/ccCallFeature:
   Feature Type=25, Call Id=1486
Feb 14 01:04:25.988: //1486/C74292F49068/CCAPI/cc_api_voice_mode_event:
   Call Id=1486
   Call Entry(Context=0x47D7EC18)
Feb 14 01:04:25.988: //1487/C74292F49068/CCAPI/cc_api_voice_mode_event:
   Call Id=1487
Feb 14 01:04:25.992: //1487/C74292F49068/CCAPI/cc_api_voice_mode_event:
   Call Entry(Context=0x47D6FBB8)
Feb 14 01:04:25.992: //1486/C74292F49068/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x1AC, Call Id1=1486, Call Id2=1487
Feb 14 01:04:30.176: //1486/C74292F49068/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x4B53AD64, Call Id=1486
Feb 14 01:04:30.176: //1486/C74292F49068/CCAPI/ccConferenceDestroy:
   Conference Id=0x1AC, Tag=0x0
Feb 14 01:04:30.176: //1486/C74292F49068/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=1487, Disposition=0x0, Tag=0x0
Feb 14 01:04:30.176: //1487/C74292F49068/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=1486, Disposition=0x0, Tag=0x0
Feb 14 01:04:30.176: //1486/C74292F49068/CCAPI/cc_generic_bridge_done:
Feb 14 01:04:30.176: //1487/C74292F49068/CCAPI/ccCallDisconnect:
Feb 14 01:04:30.176: //1487/C74292F49068/CCAPI/cc_api_get_transfer_info:
Feb 14 01:04:30.180: //1486/C74292F49068/CCAPI/ccCallDisconnect:
Feb 14 01:04:30.180: //1486/C74292F49068/CCAPI/cc_api_get_transfer_info:
Feb 14 01:04:30.184: //1486/C74292F49068/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x4B53AD64, Tag=0x0, Call Id=1486,
Feb 14 01:04:30.184: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Feb 14 01:04:30.184: :cc_free_feature_vsa freeing 47D561E8
Feb 14 01:04:30.184:  vsacount in free is 5
Feb 14 01:04:30.184:  vsacount in free is 4
Feb 14 01:04:30.220: //1487/C74292F49068/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x4A0C1364, Tag=0x0, Call Id=1487,
Feb 14 01:04:30.224: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Feb 14 01:04:30.224: :cc_free_feature_vsa freeing 47D56488
Feb 14 01:04:30.224:  vsacount in free is 3
Feb 14 01:04:30.224:  vsacount in free is 2
chrs-phx-cme# u all
% Ambiguous command:  " u all"
chrs-phx-cme#u all
chrs-phx-cme#debug voice dialpeer
voip dialpeer default debugging is on
sabled)
    Buffer logging:  level debugging, 1145 messages logged, xml disabled,
                    filtering disabled
   cisco-username=
   cisco-ani=142
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
   Set Up Event Sent;
   Event=0x4943C8E0
   Context=0x47D7EC18
   Call Id=1486
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=142
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=9602XXXX03
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=73
   cisco-rdn=123
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
llowed),
   Context=0x47D6FBB8
   Cause Value=0
   Call Id=1486
   Call Id=1487
Feb 14 01:04:53.524: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=142, Called Number=, Voice-Interface=0x4B53AD64,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
   Peer Info Type=DIALPEER_INFO_SPEECH
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=20027
Feb 14 01:04:53.524: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
Feb 14 01:04:54.036: //-1/D8B212A79070/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=1, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=1
   Result=Partial Matches(1) after DP_MATCH_DEST
Feb 14 01:04:54.036: //-1/D8B212A79070/DPM/dpMatchSafModulePlugin:
   dialstring=1, saf_enabled=1, saf_dndb_lookup=0, dp_result=1
Feb 14 01:04:54.036: //-1/D8B212A79070/DPM/dpMatchPeersMoreArg:
   Result=MORE_DIGITS_NEEDED(1)
Feb 14 01:04:54.132: //-1/D8B212A79070/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=12, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=12
Feb 14 01:04:54.132: //-1/D8B212A79070/DPM/dpMatchSafModulePlugin:
   dialstring=12, saf_enabled=1, saf_dndb_lookup=0, dp_result=1
Feb 14 01:04:54.132: //-1/D8B212A79070/DPM/dpMatchPeersMoreArg:
Feb 14 01:04:54.232: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=123, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=123
Feb 14 01:04:54.236: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Result=Success(0) after DP_MATCH_DEST
Feb 14 01:04:54.236: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=123, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
Feb 14 01:04:54.236: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=20011
Feb 14 01:04:54.236: //-1/D8B212A79070/DPM/dpMatchPeersCore:
Feb 14 01:04:54.236: //-1/D8B212A79070/DPM/dpMatchSafModulePlugin:
   dialstring=123, saf_enabled=1, saf_dndb_lookup=0, dp_result=0
Feb 14 01:04:54.236: //-1/D8B212A79070/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
Feb 14 01:04:54.240: //-1/D8B212A79070/DPM/dpMatchPeersCore:
Feb 14 01:04:54.240: //-1/D8B212A79070/DPM/dpMatchSafModulePlugin:
Feb 14 01:04:54.240: //-1/D8B212A79070/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   Result=SUCCESS(0)
Feb 14 01:04:54.240: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=123, Called Number=123, Peer Info Type=DIALPEER_INFO_SPEECH
Feb 14 01:04:54.240: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Feb 14 01:04:54.240: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   Calling Number=, Called Number=9602XXXX03, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=9602XXXX03
   dialstring=9602XXXX03, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
   Result=SUCCESS(0)
     1: Dial-peer Tag=8
     2: Dial-peer Tag=19
Feb 14 01:04:54.244: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=, Called Number=, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
   Result=NO_MATCH(-1) After All Match Rules Attempt
Feb 14 01:04:54.244: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=-1
   Calling Number=123, Called Number=, Voice-Interface=0x0,
Feb 14 01:04:54.244: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Feb 14 01:04:54.244: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
Feb 14 01:04:54.244: //-1/D8B212A79070/DPM/dpMatchPeersCore:
Feb 14 01:04:54.244: //-1/D8B212A79070/DPM/dpMatchSafModulePlugin:
   dialstring=123, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
Feb 14 01:04:54.244: //-1/D8B212A79070/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
Feb 14 01:04:54.248: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Feb 14 01:04:54.248: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Feb 14 01:04:54.248: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=8
     2: Dial-peer Tag=19
   Result=SUCCESS(0)
     1: Dial-peer Tag=8
     2: Dial-peer Tag=19
   dialstring=9602XXXX03, saf_enabled=0, saf_dndb_lookup=1, dp_result=1
Feb 14 01:04:54.252: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=9602XXXX03, Called Number=, Voice-Interface=0x0,
Feb 14 01:04:54.252: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Feb 14 01:04:54.252: //-1/D9208C6C9074/DPM/dpMatchPeersCore:
Feb 14 01:04:54.252: //-1/D9208C6C9074/DPM/dpMatchSafModulePlugin:
   dialstring=9602XXXX03, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
Feb 14 01:04:54.252: //-1/D9208C6C9074/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=8
     2: Dial-peer Tag=19
Feb 14 01:04:54.384: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=142, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=142
Feb 14 01:04:54.384: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Feb 14 01:04:54.384: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
     1: Dial-peer Tag=20027
   Calling Number=, Called Number=602XXXX03, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=602XXXX03
   No Outgoing Dial-peer Is Matched; Result=NO_MATCH(-1)
Feb 14 01:04:54.388: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=NO_MATCH(-1)
Feb 14 01:04:54.388: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Feb 14 01:04:54.388: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=602XXXX03, saf_enabled=0, saf_dndb_lookup=1, dp_result=-1
Feb 14 01:04:54.388: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=NO_MATCH(-1)
Feb 14 01:04:55.332: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Feb 14 01:04:55.332: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Feb 14 01:04:55.332: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=8
     2: Dial-peer Tag=19
chrs-phx-cme#
Thank you for taking a look at this for me.
Jason
Hi.
Can you please add "call-forward pattern .T" under telephony service?
Let me know
regards
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
Beginner
Carlo,
That didn't help.
Here are the debugs and the telephony configuration:
telephony-service
sdspfarm units 2
sdspfarm tag 2 DSPprofile2
conference hardware
authentication credential admin cisco
max-ephones 58
max-dn 192
ip source-address 192.168.0.8 port 2000
auto assign 100 to 150
timeouts interdigit 5
system message Making A Difference!
url services http://192.168.0.9/voiceview/common/login.do
url authentication http://192.168.0.8/CCMCIP/authenticate.asp
cnf-file location flash:
load 7912 CP7912080004SCCP080108A.sbin
load 7960-7940 P00308010200.loads
load 7941 SCCP41.9-1-1SR1S.loads
load 7970 SCCP70.9-1-1SR1S.loads
time-zone 7
voicemail 777
mwi relay
max-conferences 4 gain -6
moh flash:/music-on-hold.au
multicast moh 239.1.1.1 port 16384
web admin system name admin secret 5 XXXXXX
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern .T
secondary-dialtone 9
directory last-name-first
debug isdn q931
Feb 14 18:44:28.960: ISDN Se0/3/0:23 Q931: Applying typeplan for sw-type 0xD is
0x0 0x0, Calling num 123
Feb 14 18:44:28.960: ISDN Se0/3/0:23 Q931: Sending SETUP  callref = 0x0108 callI
D = 0x8089 switch = primary-ni interface = User
Feb 14 18:44:28.964: ISDN Se0/3/0:23 Q931: TX -> SETUP pd = 8  callref = 0x0108
                Standard = CCITT
                Transfer Mode = Circuit602XXX403
        Calling Party Number i = 0x0080, '123'
        Called Party Number i = 0xA1, '602XXX403'
        Redirecting Number i = 0x00008F, '142'
Feb 14 18:44:28.980: ISDN Se0/3/0:23 Q931: RX <- CALL_PROC pd = 8  callref = 0x8
108
Feb 14 18:44:29.080: ISDN Se0/3/0:23 Q931: RX <- PROGRESS pd = 8  callref = 0x81
08
Feb 14 18:44:34.392: ISDN Se0/3/0:23 Q931: TX -> DISCONNECT pd = 8  callref = 0x
0108
Feb 14 18:44:34.420: ISDN Se0/3/0:23 Q931: RX <- RELEASE pd = 8  callref = 0x810
8
Feb 14 18:44:34.420: ISDN Se0/3/0:23 Q931: TX -> RELEASE_COMP pd = 8  callref =
0x0108
chrs-phx-cme#
Feb 14 18:46:47.324: //-1/311323DE9482/CCAPI/cc_api_display_ie_subfields:
   cisco-username=
   cisco-ani=123
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
Feb 14 18:46:47.324: //-1/311323DE9482/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x4B466C4C, Call Info(
   Calling Number=123,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Sc
ag=FALSE,
   Incoming Dial-peer=20011, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
E), Call Id=-1
Feb 14 18:46:47.324: //-1/311323DE9482/CCAPI/ccCheckClipClir:
   In: Calling Number=123(TON=Unknown, NPI=Unknown, Screening=Not Screened, Pres
entation=Allowed)
   Out: Calling Number=123(TON=Unknown, NPI=Unknown, Screening=Not Screened, Pre
sentation=Allowed)
Feb 14 18:46:47.324: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Feb 14 18:46:47.324: :cc_get_feature_vsa malloc success
Feb 14 18:46:47.324:  cc_get_feature_vsa count is 1
Feb 14 18:46:47.324: :FEATURE_VSA attributes are: feature_name:0,feature_time:12
05170608,feature_id:3455
Feb 14 18:46:47.324: //1855/311323DE9482/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=123(TON=Unknown, NPI=Unknown, Screening=Not Screened
Feb 14 18:46:47.328: //1855/311323DE9482/CCAPI/cc_process_call_setup_ind:
   Event=0x494443E0
Feb 14 18:46:47.328: //1855/311323DE9482/CCAPI/ccCallSetContext:
   Context=0x47D69790
   >>>>CCAPI handed cid 1855 with tag 20011 to app "_ManagedAppProcess_Default"
Feb 14 18:46:47.332: //1855/311323DE9482/CCAPI/ccCallSetupAck:
   Call Id=1855
Feb 14 18:46:47.332: //1855/311323DE9482/CCAPI/cc_api_set_transfer_info:
Feb 14 18:46:47.332: //1855/311323DE9482/CCAPI/ccGenerateToneInfo:
   Tone Direction=Network, Params=0x0, Call Id=1855
Feb 14 18:46:47.332: //1855/311323DE9482/CCAPI/ccSetDigitTimeouts:
Feb 14 18:46:47.332: //1855/311323DE9482/CCAPI/ccCallReportDigits:
   (callID=0x73F, digit_event=0x1, enable=TRUE, consume=FALSE)
   Enabled=TRUE, Call Id=1855
Feb 14 18:46:47.332: //1855/311323DE9482/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x4B466C4C, callID=0x73F, disp=0, digit_event=0x1, enable=TRUE, consu
me=FALSE)
   Enabled=TRUE, Disposition=0x0, Interface=0x4B466C4C, Call Id=1855
Feb 14 18:46:47.828: //1855/311323DE9482/CCAPI/cc_api_call_digit_begin:
   Source Call Id=1855, Digit=1, DigitBeginFlags=0x0,
   Rtp Timestamp=0x5BDBA0, Rtp Expiration=0x0
Feb 14 18:46:47.828: //1855/311323DE9482/CCAPI/cc_api_call_digit_end:
   Source Call Id=1855, Digit=1, Duration=100,
Feb 14 18:46:47.928: //1855/311323DE9482/CCAPI/cc_api_call_digit_begin:
   Source Call Id=1855, Digit=4, DigitBeginFlags=0x0,
   Rtp Timestamp=0x5C58A0, Rtp Expiration=0x0
Feb 14 18:46:47.928: //1855/311323DE9482/CCAPI/cc_api_call_digit_end:
   Source Call Id=1855, Digit=4, Duration=100,
Feb 14 18:46:48.032: //1855/311323DE9482/CCAPI/cc_api_call_digit_begin:
   Source Call Id=1855, Digit=2, DigitBeginFlags=0x0,
   Rtp Timestamp=0x5CD5A0, Rtp Expiration=0x0
Feb 14 18:46:48.032: //1855/311323DE9482/CCAPI/cc_api_call_digit_end:
   Source Call Id=1855, Digit=2, Duration=100,
Feb 14 18:46:48.032: //1855/311323DE9482/CCAPI/ccCallReportDigits:
   (callID=0x73F, digit_event=0x0, enable=FALSE, consume=FALSE)
Feb 14 18:46:48.032: //1855/311323DE9482/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x4B466C4C, callID=0x73F, disp=0, digit_event=0x0, enable=FALSE, cons
ume=FALSE)
Feb 14 18:46:48.032: //1855/311323DE9482/CCAPI/ccCallProceeding:
Feb 14 18:46:48.036: //-1/xxxxxxxxxxxx/CCAPI/ccUpdateRedirectingNumber:
   type=6 redirecting_number=142
Feb 14 18:46:48.036: //-1/xxxxxxxxxxxx/CCAPI/ccUpdateRedirectNumber:
   type=6  Original Called Number=142, Called Number=142, Calling Number=123, Ca
lling DN=88 Calling Id=1855,
   Redirect Number=9602XXX403, Redirect Reason=15
Feb 14 18:46:48.036: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Feb 14 18:46:48.036: :cc_get_feature_vsa malloc success
Feb 14 18:46:48.036:  cc_get_feature_vsa count is 2
Feb 14 18:46:48.036: :FEATURE_VSA attributes are: feature_name:0,feature_time:12
05170384,feature_id:3456
Feb 14 18:46:48.036: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
Feb 14 18:46:48.036:  feature_vsa is 47D571A8,featname is 0
Feb 14 18:46:48.040: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Feb 14 18:46:48.040: :cc_get_feature_vsa malloc success
Feb 14 18:46:48.040:  cc_get_feature_vsa count is 3
Feb 14 18:46:48.040: :FEATURE_VSA attributes are: feature_name:0,feature_time:12
05165904,feature_id:3457
Feb 14 18:46:48.040: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
Feb 14 18:46:48.040: : Generating new featurevsa,inserting it
Feb 14 18:46:48.040:  feature call forward featname is 1
Feb 14 18:46:48.040: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Feb 14 18:46:48.040: :cc_free_feature_vsa freeing 47D570C8
Feb 14 18:46:48.040:  vsacount in free is 2
Feb 14 18:46:48.040: //1855/311323DE9482/CCAPI/ccCallForwardTo:
   Call Forward Number=9602XXX403, Call Forward Cause Reason=15, Call Id=1855
05170384,feature_id:3458
Feb 14 18:46:48.044: //1855/311323DE9482/CCAPI/ccCallForwardTo:
Feb 14 18:46:48.044: //1855/311323DE9482/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=8, Params=0x47D7B050, Progress Indication=ORIGINATING SIDE
IS NON ISDN(3)
Feb 14 18:46:48.044: //1855/311323DE9482/CCAPI/ccCheckClipClir:
entation=Allowed)
sentation=Allowed)
   Destination Pattern=9T, Called Number=9602XXX403, Digit Strip=TRUE
tion=Allowed),
   Called Number=9602XXX403(TON=Unknown, NPI=Unknown),
   Redirect Number=142, Display Info=SteveG
   Guid=31819DA3-94DF-11E3-9486-ECFAA818FF8E, Outgoing Dial-peer=8
Feb 14 18:46:48.048: //1855/311323DE9482/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=123
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=9602XXX403
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=73
   cisco-rdn=142
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
Feb 14 18:46:48.048: //1855/311323DE9482/CCAPI/ccIFCallSetupRequestPrivate:
   Called Number=9602XXX403(TON=Unknown, NPI=Unknown), Calling Translated=FALSE
ication Call Id=)
Feb 14 18:46:48.048: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Feb 14 18:46:48.048: :cc_get_feature_vsa malloc success
Feb 14 18:46:48.048:  cc_get_feature_vsa count is 3
Feb 14 18:46:48.048: :FEATURE_VSA attributes are: feature_name:0,feature_time:12
05170384,feature_id:3459
Feb 14 18:46:48.048: //1856/311323DE9482/CCAPI/ccIFCallSetupRequestPrivate:
Feb 14 18:46:48.048: //1856/311323DE9482/CCAPI/ccCallSetContext:
   Context=0x47D7B000
Feb 14 18:46:48.048: //1855/311323DE9482/CCAPI/ccSaveDialpeerTag:
Feb 14 18:46:48.048: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
Feb 14 18:46:48.048:  feature call forward featname is 1
Feb 14 18:46:48.048:  feature_vsa is 47D570C8,featname is 0
Feb 14 18:46:48.048:  cc_get_feature_vsa count is 4
05170160,feature_id:3460
Feb 14 18:46:48.048: : Generating new featurevsa,inserting it
Feb 14 18:46:48.072: //1856/311323DE9482/CCAPI/cc_api_call_proceeding:
Feb 14 18:46:48.172: //1856/311323DE9482/CCAPI/cc_api_call_cut_progress:
EPT(2),
   Cause Value=0
Feb 14 18:46:48.172: //1855/311323DE9482/CCAPI/ccCallCutProgress:
Feb 14 18:46:48.172: //1855/311323DE9482/CCAPI/ccGenerateToneInfo:
Feb 14 18:46:48.172: //1855/311323DE9482/CCAPI/ccConferenceCreate:
   (confID=0x4BCAA2C4, callID1=0x73F, gcid=311323DE-94DF11E3-9482ECFA-A818FF8E,
tag=0x0)
Feb 14 18:46:48.172: //1856/311323DE9482/CCAPI/ccConferenceCreate:
   (confID=0x4BCAA2C4, callID2=0x740, gcid=311323DE-94DF11E3-9482ECFA-A818FF8E,
tag=0x0)
   Conference Id=0x4BCAA2C4, Call Id1=1855, Call Id2=1856, Tag=0x0
Feb 14 18:46:48.172: //1855/311323DE9482/CCAPI/cc_api_bridge_done:
   Conference Id=0x221, Source Interface=0x4B466C4C, Source Call Id=1855,
   Destination Call Id=1856, Disposition=0x0, Tag=0xFFFFFFFF
Feb 14 18:46:48.172: //1856/311323DE9482/CCAPI/cc_api_bridge_done:
   Conference Id=0x221, Source Interface=0x4A0C1364, Source Call Id=1856,
   Destination Call Id=1855, Disposition=0x0, Tag=0xFFFFFFFF
Feb 14 18:46:48.172: //1855/311323DE9482/CCAPI/cc_generic_bridge_done:
Feb 14 18:46:48.176: //1855/311323DE9482/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x221, Destination Call Id=1856)
Feb 14 18:46:48.176: //1856/311323DE9482/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x221, Destination Call Id=1855)
Feb 14 18:46:48.176: //1855/311323DE9482/CCAPI/cc_api_caps_ind:
   Destination Interface=0x4A0C1364, Destination Call Id=1856, Source Call Id=18
55,
Feb 14 18:46:48.176: //1856/311323DE9482/CCAPI/cc_api_caps_ind:
   Destination Interface=0x4B466C4C, Destination Call Id=1855, Source Call Id=18
56,
Feb 14 18:46:48.176: //1856/311323DE9482/CCAPI/cc_api_caps_ack:
56,
   Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=615)
Feb 14 18:46:48.176: //1855/311323DE9482/CCAPI/cc_api_caps_ack:
55,
   Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=2226)
Feb 14 18:46:48.176: //1855/311323DE9482/CCAPI/ccCallFeature:
   Feature Type=25, Call Id=1855
Feb 14 18:46:48.180: //1855/311323DE9482/CCAPI/cc_api_voice_mode_event:
   Call Id=1855
   Call Entry(Context=0x47D69790)
Feb 14 18:46:48.180: //1856/311323DE9482/CCAPI/cc_api_voice_mode_event:
   Call Id=1856
   Call Entry(Context=0x47D7B000)
Feb 14 18:46:48.180: //1855/311323DE9482/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x221, Call Id1=1855, Call Id2=1856
Feb 14 18:46:58.632: //1856/311323DE9482/CCAPI/cc_api_call_disconnected:
   Cause Value=18, Interface=0x4A0C1364, Call Id=1856
Feb 14 18:46:58.636: //1855/311323DE9482/CCAPI/ccCallReleaseResources:
Feb 14 18:46:58.636: //1856/311323DE9482/CCAPI/ccCallSetAAA_Accounting:
   Accounting=1, Call Id=1856
Feb 14 18:46:58.636: //1855/311323DE9482/CCAPI/ccConferenceDestroy:
   Conference Id=0x221, Tag=0x0
Feb 14 18:46:58.636: //1855/311323DE9482/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=1856, Disposition=0x0, Tag=0x0
Feb 14 18:46:58.636: //1856/311323DE9482/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=1855, Disposition=0x0, Tag=0x0
Feb 14 18:46:58.636: //1855/311323DE9482/CCAPI/cc_generic_bridge_done:
Feb 14 18:46:58.636: //1856/311323DE9482/CCAPI/ccCallDisconnect:
ause=18)
Feb 14 18:46:58.636: //1856/311323DE9482/CCAPI/cc_api_get_transfer_info:
Feb 14 18:46:58.636: //1855/311323DE9482/CCAPI/ccGenerateToneInfo:
Feb 14 18:46:58.656: //1856/311323DE9482/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x4A0C1364, Tag=0x0, Call Id=1856,
Feb 14 18:46:58.656: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Feb 14 18:46:58.656: :cc_free_feature_vsa freeing 47D56FE8
Feb 14 18:46:58.656:  vsacount in free is 3
Feb 14 18:46:58.656:  vsacount in free is 2
Feb 14 18:46:58.660: //1855/311323DE9482/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=19, Params=0x47D7EC68, Progress Indication=ORIGINATING SID
E IS NON ISDN(3)
Feb 14 18:46:58.660: //1855/311323DE9482/CCAPI/ccCheckClipClir:
entation=Allowed)
sentation=Allowed)
tion=Allowed),
   Guid=31819DA3-94DF-11E3-9486-ECFAA818FF8E, Outgoing Dial-peer=19
Feb 14 18:46:58.660: //1855/311323DE9482/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=123
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=9602XXX403
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=73
   cisco-rdn=142
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
Feb 14 18:46:58.660: //1855/311323DE9482/CCAPI/ccIFCallSetupRequestPrivate:
ication Call Id=)
Feb 14 18:46:58.660: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Feb 14 18:46:58.660: :cc_get_feature_vsa malloc success
Feb 14 18:46:58.660:  cc_get_feature_vsa count is 3
Feb 14 18:46:58.660: :FEATURE_VSA attributes are: feature_name:0,feature_time:12
05170384,feature_id:3461
Feb 14 18:46:58.660: //1857/311323DE9482/CCAPI/ccIFCallSetupRequestPrivate:
Feb 14 18:46:58.660: //1857/311323DE9482/CCAPI/ccCallSetContext:
   Context=0x47D7EC18
Feb 14 18:46:58.660: //1855/311323DE9482/CCAPI/ccSaveDialpeerTag:
Feb 14 18:46:58.664: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
Feb 14 18:46:58.664:  feature call forward featname is 1
Feb 14 18:46:58.664:  feature_vsa is 47D570C8,featname is 0
Feb 14 18:46:58.664: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Feb 14 18:46:58.664: :cc_get_feature_vsa malloc success
Feb 14 18:46:58.664:  cc_get_feature_vsa count is 4
Feb 14 18:46:58.664: :FEATURE_VSA attributes are: feature_name:0,feature_time:12
05170160,feature_id:3462
Feb 14 18:46:58.664: : Generating new featurevsa,inserting it
Feb 14 18:46:58.692: //1857/311323DE9482/CCAPI/cc_api_call_proceeding:
Feb 14 18:46:58.792: //1857/311323DE9482/CCAPI/cc_api_call_cut_progress:
EPT(2),
   Cause Value=0
Feb 14 18:46:58.792: //1855/311323DE9482/CCAPI/ccCallCutProgress:
Feb 14 18:46:58.792: //1855/311323DE9482/CCAPI/ccGenerateToneInfo:
Feb 14 18:46:58.792: //1855/311323DE9482/CCAPI/ccConferenceCreate:
   (confID=0x4BCAA1EC, callID1=0x73F, gcid=311323DE-94DF11E3-9482ECFA-A818FF8E,
tag=0x0)
Feb 14 18:46:58.792: //1857/311323DE9482/CCAPI/ccConferenceCreate:
   (confID=0x4BCAA1EC, callID2=0x741, gcid=311323DE-94DF11E3-9482ECFA-A818FF8E,
tag=0x0)
   Conference Id=0x4BCAA1EC, Call Id1=1855, Call Id2=1857, Tag=0x0
Feb 14 18:46:58.796: //1855/311323DE9482/CCAPI/cc_api_bridge_done:
   Conference Id=0x222, Source Interface=0x4B466C4C, Source Call Id=1855,
   Destination Call Id=1857, Disposition=0x0, Tag=0xFFFFFFFF
Feb 14 18:46:58.796: //1857/311323DE9482/CCAPI/cc_api_bridge_done:
   Conference Id=0x222, Source Interface=0x4A0C1364, Source Call Id=1857,
Feb 14 18:46:58.796: //1855/311323DE9482/CCAPI/cc_generic_bridge_done:
Feb 14 18:46:58.796: //1855/311323DE9482/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x222, Destination Call Id=1857)
Feb 14 18:46:58.796: //1857/311323DE9482/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x222, Destination Call Id=1855)
Feb 14 18:46:58.796: //1855/311323DE9482/CCAPI/cc_api_caps_ind:
   Destination Interface=0x4A0C1364, Destination Call Id=1857, Source Call Id=18
55,
Feb 14 18:46:58.796: //1857/311323DE9482/CCAPI/cc_api_caps_ind:
57,
Feb 14 18:46:58.796: //1857/311323DE9482/CCAPI/cc_api_caps_ack:
57,
   Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=8905)
Feb 14 18:46:58.796: //1855/311323DE9482/CCAPI/cc_api_caps_ack:
55,
   Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=9626)
Feb 14 18:46:58.800: //1855/311323DE9482/CCAPI/ccCallFeature:
Feb 14 18:46:58.800: //1855/311323DE9482/CCAPI/cc_api_voice_mode_event:
   Call Id=1855
Feb 14 18:46:58.804: //1857/311323DE9482/CCAPI/cc_api_voice_mode_event:
   Call Id=1857
Feb 14 18:46:58.804: //1855/311323DE9482/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x222, Call Id1=1855, Call Id2=1857
Feb 14 18:46:59.468: //1855/311323DE9482/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x4B466C4C, Call Id=1855
Feb 14 18:46:59.468: //1855/311323DE9482/CCAPI/ccConferenceDestroy:
   Conference Id=0x222, Tag=0x0
Feb 14 18:46:59.468: //1855/311323DE9482/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=1857, Disposition=0x0, Tag=0x0
Feb 14 18:46:59.468: //1857/311323DE9482/CCAPI/cc_api_bridge_drop_done:
Feb 14 18:46:59.468: //1855/311323DE9482/CCAPI/cc_generic_bridge_done:
Feb 14 18:46:59.468: //1857/311323DE9482/CCAPI/ccCallDisconnect:
ause=0)
Feb 14 18:46:59.468: //1857/311323DE9482/CCAPI/cc_api_get_transfer_info:
Feb 14 18:46:59.472: //1855/311323DE9482/CCAPI/ccCallDisconnect:
ause=16)
Feb 14 18:46:59.472: //1855/311323DE9482/CCAPI/cc_api_get_transfer_info:
Feb 14 18:46:59.476: //1855/311323DE9482/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x4B466C4C, Tag=0x0, Call Id=1855,
Feb 14 18:46:59.476: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Feb 14 18:46:59.476: :cc_free_feature_vsa freeing 47D55F48
Feb 14 18:46:59.476:  vsacount in free is 3
Feb 14 18:46:59.476:  vsacount in free is 2
Feb 14 18:46:59.516: //1857/311323DE9482/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x4A0C1364, Tag=0x0, Call Id=1857,
Feb 14 18:46:59.516: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Feb 14 18:46:59.516: :cc_free_feature_vsa freeing 47D56FE8
Feb 14 18:46:59.516:  vsacount in free is 1
Feb 14 18:46:59.516:  vsacount in free is 0
chrs-phx-cme#
Feb 14 18:48:08.440: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=123, Called Number=, Voice-Interface=0x4B466C4C,
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=20011
Feb 14 18:48:08.440: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Feb 14 18:48:08.936: //-1/616D116F948B/DPM/dpMatchPeersCore:
Feb 14 18:48:08.936: //-1/616D116F948B/DPM/dpMatchSafModulePlugin:
Feb 14 18:48:08.936: //-1/616D116F948B/DPM/dpMatchPeersMoreArg:
Feb 14 18:48:09.036: //-1/616D116F948B/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=14, Peer Info Type=DIALPEER_INFO_SPEECH
Feb 14 18:48:09.036: //-1/616D116F948B/DPM/dpMatchSafModulePlugin:
   dialstring=14, saf_enabled=1, saf_dndb_lookup=0, dp_result=1
Feb 14 18:48:09.036: //-1/616D116F948B/DPM/dpMatchPeersMoreArg:
Feb 14 18:48:09.136: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Feb 14 18:48:09.136: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=142, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
Feb 14 18:48:09.136: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
Feb 14 18:48:09.140: //-1/616D116F948B/DPM/dpMatchPeersCore:
Feb 14 18:48:09.140: //-1/616D116F948B/DPM/dpMatchSafModulePlugin:
   dialstring=142, saf_enabled=1, saf_dndb_lookup=0, dp_result=0
Feb 14 18:48:09.140: //-1/616D116F948B/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   Result=SUCCESS(0)
Feb 14 18:48:09.144: //-1/616D116F948B/DPM/dpMatchPeersCore:
Feb 14 18:48:09.144: //-1/616D116F948B/DPM/dpMatchSafModulePlugin:
Feb 14 18:48:09.144: //-1/616D116F948B/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
Feb 14 18:48:09.144: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=142, Called Number=142, Peer Info Type=DIALPEER_INFO_SPEECH
Feb 14 18:48:09.144: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Feb 14 18:48:09.144: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   Calling Number=, Called Number=9602XXX403, Peer Info Type=DIALPEER_INFO_SPEE
CH
   Match Rule=DP_MATCH_DEST; Called Number=9602XXX403
   dialstring=9602XXX403, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
   Result=SUCCESS(0)
     1: Dial-peer Tag=8
     2: Dial-peer Tag=19
Feb 14 18:48:09.144: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=142, Called Number=, Voice-Interface=0x0,
   Result=SUCCESS(0)
Feb 14 18:48:09.148: //-1/616D116F948B/DPM/dpMatchPeersCore:
Feb 14 18:48:09.148: //-1/616D116F948B/DPM/dpMatchSafModulePlugin:
   dialstring=142, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
Feb 14 18:48:09.148: //-1/616D116F948B/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
Feb 14 18:48:09.148: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
CH
Feb 14 18:48:09.148: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Feb 14 18:48:09.148: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=8
     2: Dial-peer Tag=19
CH
   Result=SUCCESS(0)
     1: Dial-peer Tag=8
     2: Dial-peer Tag=19
CH
   dialstring=9602XXX403, saf_enabled=0, saf_dndb_lookup=1, dp_result=1
Feb 14 18:48:09.152: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=9602XXX403, Called Number=, Voice-Interface=0x0,
Feb 14 18:48:09.152: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Feb 14 18:48:09.156: //-1/61DA52E4948F/DPM/dpMatchPeersCore:
CH
Feb 14 18:48:09.156: //-1/61DA52E4948F/DPM/dpMatchSafModulePlugin:
   dialstring=9602XXX403, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
Feb 14 18:48:09.156: //-1/61DA52E4948F/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=8
     2: Dial-peer Tag=19
Feb 14 18:48:09.280: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Feb 14 18:48:09.280: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Feb 14 18:48:09.280: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
   Calling Number=, Called Number=602XXX403, Peer Info Type=DIALPEER_INFO_SPEEC
H
   Match Rule=DP_MATCH_DEST; Called Number=602XXX403
   Result=NO_MATCH(-1)
Feb 14 18:48:09.284: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
H
Feb 14 18:48:09.284: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=602XXX403, saf_enabled=0, saf_dndb_lookup=1, dp_result=-1
Feb 14 18:48:09.284: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=NO_MATCH(-1)
Feb 14 18:48:09.328: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
CH
Feb 14 18:48:09.328: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Feb 14 18:48:09.328: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=8
     2: Dial-peer Tag=19
Rising star
CFWD goes busy, but regular call works
Can you post your dial-peers?
Yosh
HTH Regards, Yosh
Highlighted
Beginner
Here are the dial-peers:
chrs-phx-cme#sh run | sec dial-peer
dial-peer voice 10 voip
destination-pattern 778
session protocol sipv2
session target ipv4:192.168.0.9
codec g711ulaw
no vad
dial-peer voice 11 voip
destination-pattern 779
codec g711ulaw
no vad
dial-peer voice 777 voip
description Cisco Unity Express voicemail pilot number
destination-pattern 777
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 776 voip
description Cisco Unity AA
destination-pattern 776
codec g711ulaw
no vad
dial-peer voice 775 voip
description Cisco Unity AA-admin
destination-pattern 775
codec g711ulaw
no vad
dial-peer voice 443 pots
destination-pattern 443
port 0/1/3
forward-digits 0
dial-peer voice 444 pots
description Bogen Paging Adapter
service stcapp
port 0/2/0
dial-peer voice 5 pots
description inbound PRI DP
translation-profile incoming from_pri
incoming called-number .
port 0/3/0:23
no sip-register
dial-peer voice 19 pots
description PRI outbound
preference 2
destination-pattern 9T
port 0/3/0:23
no sip-register
dial-peer voice 8 pots
description PRI
preference 1
port 0/3/0:23
no sip-register
chrs-phx-cme#
Beginner
Did anyone check the css for forwarding ?
Beginner
Does CME use CSS?
Content for Community-Ad
August's Community Spotlight Awards
