Changing default Unity System prompts
t.guerriero
I am deploying a Unity server that is replacing an I3 server. Customer wants all system prompts to match identically. I have used the Conversation 1 which most closely resembles what they have in place today. This is not close enough. Is there a way to change the defaults as far as what number corresponds to what function ie: using the number 5 to access personal options instead of the number 4? I don't think it is possible to alter the conversation, but I need to find out for sure. There is no way to change any registry settings via the Advanced settings tool, but can it be done manually?
Ginger Dillon
Hi -
Unity 4.0(5) has in the Unity Tools Depot, a Custom Key Map. You will find it in the Administration Tools. I've never used it because we use the Optional Conversation 1 to mirror Octel voicemail. But there is online help available if you double-click on it.
Sincerely,
Ginger
