987
GLIDE
Beginner
Cisco 2811 Router will not activate paging system via FXO Port - No more Routes in RouteListName, Cause Code 34
Hello, we’re are making a last-ditch effort to see if someone in the community has some advice on this problem as we are stumped and it’s looking like we will need additional equipment that we didn’t plan on getting yet. We have CUCM (V. 8.6.2.20000-2) operating in 2 buildings, connected with a VPN tunnel, and Cisco endpoint phones working for a while now. We are in the process of moving some of our users in our main building to Skype for Business, and all of our users in our 2nd building, which is where we are having the problem I am describing.
We have had our teams exhaustively troubleshot this, with help from Cisco, and are a bit stuck. If anyone has any suggestions, it would be greatly appreciated! I’m going to paste some of the Cisco 2811 current-config at the end of this post.
Thanks in advance for your time if you read this!
The main issue right now:
- Cisco 2811 Router FXO port no longer activates a Valcom V-2006a overhead paging system, when dialed through CUCM, both systems do not have official vendor support.
More details:
We use an overhead paging system for announcements (mainly fire drills/emergency notifications) in our 2nd building. On our legacy CUCM phones, we could dial a ## DTMF code, which dialed a gateway, to access this system. It’s now unusable, after making no changes, except implementation of an upgrade to SfB softphones for our users in that building and changes made to the Cisco 2811 router that activates that system which was backed out.
The CUCM system is tied in via a network connection to the Cisco 2811 router, in turn connected to an older Valcom V-2006a paging system, which requires a DTMF activation code of ##0 to activate the overhead paging speakers (tested, works with a test set phone hooked directly into it and dialing the DTMF code, but the 2811 router no longer activates it.)
We have had a lot of experts in the field working on this and they have come to some conclusions. Up until changes were made to our Cisco 2811 router recently for this project, this system had been tested within weeks and was working perfectly. Those changes were made by contracted experts in the field, with help from Cisco, but something went wrong and either there is a misconfiguration, or it was functioning as-is with an unknown problem for a while.
Up until now, the normal call flow of a call that activates our Cisco 2811 router’s FXO ports to dial the analog page system has looked like this:
[Phone/Endpoint] --> [CUCM SERVER] --> [MGCP GATEWAY] --> [VPN TUNNEL] --> Cisco 2811 Router FXO--> ##0 DTMF Dial which activates analog Valcom overhead paging system Our experts on this project, along with help from Cisco support, have come to this conclusion:
The reason for why this system was working up until changes to our Cisco 2811 router’s configuration were made is unknown, but since it is now out of support, we are looking at needing to replace the equipment since it’s no longer working. Cisco support has also apparently notated this is a bug in version CUCM 8.6 which we currently run.
They suggested the following 3 options:
- Restart our CUCM server, which we are going to do, tomorrow,
- Restart MGCP Gateways, which was done but did not help,
Or Upgrade to newer equipment compatible with a later version of CUCM, or an entirely different system that has support.
Here are their findings as to the problem with the call flow:
17:55:02.203 |RouteListCdrc::terminateCall - No more Routes in RouteListName = 434 Analog.  Rejecting the call|1,100,56,1.67932216^10.1.135.138^SEP002584A1B30F17:55:02.203 |RouteListCdrc::terminateCall - Sending CcRejInd, with the cause code (34), to RouteListControl because all devices are busy/stopped.|1,100,56,1.67932216^10.1.135.138^SEP002584A1B30F17:55:02.204 |RouteListCdrc::terminateCall - precedenceBlocked == 0, cause = 34|1,100,56,1.67932216^10.1.135.138^SEP002584A1B30F17:55:02.204 |RouteListCdrc::terminateCall - Sending CcRejInd, with cause code (34), to Cc because it has not sent CcRegisterPartyB to Cc.|1,100,56,1.67932216^10.1.135.138^SEP002584A1B30F
Current configuration : 9154 bytes
version 12.4
service timestamps debug datetime localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
hostname 2811MDF-434ELLIS
boot-start-marker
boot-end-marker
logging message-counter syslog
logging buffered 51200 warnings
[ REDACTED ]
aaa session-id common
clock timezone PST -8
clock summer-time PDT recurring
dot11 syslog
ip source-route
ip cef
no ip domain lookup
ip domain name glide.org
ip multicast-routing
no ipv6 cef
trunk group ANALOG
hunt-scheme sequential
voice-card 0
application
global
  service alternate default
[Redacted]
ip ssh version 2
class-map match-any AutoQoS-VoIP-RTP-Trust
match ip dscp ef
class-map match-any AutoQoS-VoIP-Control-Trust
match ip dscp cs3
match ip dscp af31
policy-map AutoQoS-Policy-Trust
class AutoQoS-VoIP-RTP-Trust
    priority percent 70
class AutoQoS-VoIP-Control-Trust
    bandwidth percent 5
class class-default
    fair-queue
interface Tunnel0
ip address 1.1.2.2 255.255.255.0
ip pim sparse-dense-mode
no ip mroute-cache
tunnel source FastEthernet0/1
tunnel destination 10.1.50.1
interface FastEthernet0/0
description ### Uplink to LAN ###
ip address 10.2.105.5 255.255.255.0
ip flow ingress
ip flow egress
ip igmp join-group 230.20.20.20
duplex auto
speed auto
auto qos voip trust
service-policy output AutoQoS-Policy-Trust
interface FastEthernet0/1
description ### Uplink to MPLS router ###
ip address 10.2.60.2 255.255.255.252
no ip mroute-cache
duplex auto
speed auto
auto qos voip trust
interface Serial0/0/0
description $$ P2P T1 Connected to 330 ELLIS ST. $$
ip address 10.1.254.2 255.255.255.252
encapsulation ppp
shutdown
router eigrp 17218
network 10.2.20.0 0.0.0.255
network 10.2.60.0 0.0.0.3
network 10.2.80.0 0.0.0.255
network 10.2.94.0 0.0.0.255
network 10.2.95.0 0.0.0.255
network 10.2.100.0 0.0.0.255
network 10.2.105.0 0.0.0.255
network 172.16.20.0 0.0.0.255
network 192.168.30.0
no auto-summary
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 10.2.60.1
ip route 10.2.20.0 255.255.255.0 FastEthernet0/0
ip route 10.2.80.0 255.255.255.0 FastEthernet0/0
ip route 10.2.94.0 255.255.255.0 FastEthernet0/0
ip route 10.2.95.0 255.255.255.0 FastEthernet0/0
ip route 10.2.100.0 255.255.255.0 FastEthernet0/0
ip route 172.16.20.0 255.255.255.0 FastEthernet0/0
no ip http server
ip http authentication aaa login-authentication http-auth
ip http authentication aaa exec-authorization http-auth
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip flow-cache timeout active 5
ip flow-export source FastEthernet0/0
ip flow-export version 5
ip flow-export destination 10.1.20.60 9996
ip pim rp-address 10.1.50.1
ip pim spt-threshold infinity
ip mroute 10.1.135.20 255.255.255.255 Tunnel0
ip mroute 10.1.50.1 255.255.255.255 Tunnel0
logging trap warnings
logging facility local3
logging 10.1.20.60
snmp-server community Unk0d1t10n@lly RW
snmp-server ifindex persist
snmp-server location Glide
radius-server host 10.1.20.17 auth-port 1645 acct-port 1646 key 7 122B25131B1E1F23066A007B
control-plane
rmon event 33333 log trap AutoQoS description "AutoQoS SNMP traps for Voice Drops" owner AutoQoS
rmon alarm 33333 cbQosCMDropBitRate.50.14618161 30 absolute rising-threshold 1 33333 falling-threshold 0 owner AutoQoS
rmon alarm 33334 cbQosCMDropBitRate.34.5364641 30 absolute rising-threshold 1 33333 falling-threshold 0 owner AutoQoS
voice-port 0/1/0
trunk-group ANALOG 2
echo-cancel coverage 64
timing hookflash-out 50
connection plar 6200
description $$ 415-400-3796 $$
voice-port 0/1/1
trunk-group ANALOG 1
description $$ 415-400-3798 $$
voice-port 0/1/2
description $$ FXO $$
voice-port 0/1/3
voice-port 0/3/0
voice-port 0/3/1
voice-port 0/3/2
voice-port 0/3/3
ccm-manager redundant-host 10.4.20.13
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 10.1.135.12 10.4.20.13
ccm-manager config
mgcp
mgcp call-agent 10.1.135.12 2427 service-type mgcp version 0.1
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 ecm
mgcp fax t38 inhibit
mgcp bind control source-interface FastEthernet0/0
mgcp bind media source-interface FastEthernet0/0
mgcp behavior g729-variants static-pt
mgcp profile default
dial-peer voice 999010 pots
service mgcpapp
port 0/1/0
dial-peer voice 999011 pots
service mgcpapp
port 0/1/1
dial-peer voice 9007 pots
trunkgroup ANALOG
description $$ For Local Calling to 415 Area Code Only $$
destination-pattern 9[2-9]......
forward-digits 7
dial-peer voice 9011 pots
trunkgroup ANALOG
description $$ LD Calling Only $$
destination-pattern 91[2-9]..[2-9]......
forward-digits 11
dial-peer voice 911 pots
trunkgroup ANALOG
description $$ For EMERGENCY Calling Only $$
destination-pattern 911
forward-digits 3
dial-peer voice 9911 pots
trunkgroup ANALOG
destination-pattern 9911
forward-digits 3
dial-peer voice 90011 pots
trunkgroup ANALOG
description $$ For International Calling Only $$
destination-pattern 9011T
prefix 011
dial-peer voice 9411 pots
description $$ Forward 411 to GOOGLE 411 Service $$
destination-pattern 9411
prefix 18004664411
dial-peer voice 9611 pots
trunkgroup ANALOG
description $$ Service Calling Only $$
destination-pattern 9[235678]11
forward-digits 3
dial-peer voice 999033 pots
service mgcpapp
port 0/3/3
dial-peer voice 999030 pots
service mgcpapp
port 0/3/0
dial-peer voice 999031 pots
service mgcpapp
port 0/3/1
dial-peer voice 999013 pots
service mgcpapp
port 0/1/3
dial-peer voice 999012 pots
service mgcpapp
port 0/1/2
call-manager-fallback
secondary-dialtone 9
max-conferences 16 gain -6
transfer-system full-consult
ip source-address 10.2.105.5 port 2000 strict-match
max-ephones 42
max-dn 144 dual-line
system message primary GLIDE FAILOVER MODE
time-zone 5
line con 0
line aux 0
line vty 0 4
privilege level 15
transport input telnet ssh
line vty 5 15
privilege level 15
scheduler allocate 20000 1000
end
3 REPLIES 3
That SDI trace snippet suggests the MGCP port is either offhook or unregistered. What port is the Valcom connected to, what’s the port state (show voice port), and does it show registered in CUCM?
Also, did anyone touch the Valcom itself (eg connect to a different port or change DIP switch settings)?
@Jonathan Schulenberg wrote:
Also, did anyone touch the Valcom itself (eg connect to a different port or change DIP switch settings)?"
This is very important. The valcom uses a switch setting to change between Loop Start and ground start. There are 3 switches in total for this and any of them being flipped the wrong way will stop the port from working correctly.
Also be sure that the FXO port isn't stuck in an off-hook state after your page finishes. A simple shut/no shut of the port resets this. You may have to adjust disconnect signal detection on the FXO or configure ground start vs. loop start if this is a consistent issue.
Thank you for the great suggestions. We rebooted our CUCM server but it didn't resolve this.
We are looking into how the Gateways in CUCM are configured currently, as there is in fact, evidence they are not configured correctly. We are still not sure if that is the root of the problem because up until recently it was working properly and to our knowledge, these were not changed.
In CUCM we found:
1. The FXO port does show as registered, but it is registered to the Call Manager Subscriber in another location (datacenter) instead of the Publisher at our main building.
2. The FXO port shows as “Device is not trusted” in Call Manager
Nothing on the Valcom such as DIP switches were ever touched, the only thing we have ever changed was the volume, and that change was made prior to it still working via adjustment of the little board mount potentiometer. Have always been extremely careful not to disturb it for the aforementioned concern.
Thanks again for any advice.
Create
Recognize Your Peers
Content for Community-Ad
