Cisco 2911 with VIC3 E&M module does not support voice-port commands
crusco001
I have a cisco 2911 with E&M module and am unable to configure the E&M voice ports.  I assume its incorrect IOS, additional hardware or additional license required.
Any assistance is appreciated.
Router information is below.
running IOS C2900 Software (C2900-UNIVERSALK9-M), Version 15.3(3)
Cisco CISCO2911/K9 (revision 1.0) with 479232K/45056K bytes of memory.
Processor board ID FTX1840AJJT
11 Gigabit Ethernet interfaces
1 terminal line
1 Virtual Private Network (VPN) Module
2 Voice E & M interfaces
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
255488K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO2911/K9
Technology Package License Information for Module:'c2900'
Technology    Technology-package                  Technology-package
              Current              Type           Next reboot
ipbase        ipbasek9             Permanent      ipbasek9
security      securityk9           Permanent      securityk9
uc            uck9                 Permanent      uck9
data          None                 None           None
NtwkEss       None                 None           None
CollabPro     None                 None           None
Rob Huffman
Hi there,
It appears that you are missing DSP's (PVDM module) that would be required with the use of the E&M module;
http://www.cisco.com/c/en/us/support/docs/voice/call-routing-dial-plans/22377-e-doc-voice-card-recognition.html
Cheers!
Rob
[+5] to Rob.
Your UC[Voice] licenses are already installed.Check for DSPs.
you can run show inventory or show diag to check for DSP/PVDMs installed or not.
regds,
aman
