Cisco Agent ICPC can not connect outside calls
yesenia-m
In the LAN is working properly, but the moment you enter the external call and hangs want to answer.
Thank for you answer.
anchoudh
Level 9
Level 9
Hi ,
Configuration and Registration Tasks:
After you have installed the Cisco IP Communicator application, completed the Audio Tuning Wizard,
and can see the Cisco IP Communicator interface on your desktop, you may need to complete one or
more of the configuration and registration tasks listed below before you can start making calls.
Note The following tasks vary by company and phone system; your system administrator will give
you specific instructions. Do not perform these tasks unless instructed to do so.
Choosing a network adapter:
Cisco IP Communicator relies on your network adapter selection to identify itself to the network; the
correct network adapter must be selected for Cisco IP Communicator to function properly. To select
a network adapter, right-click on the Cisco IP Communicator interface, then choose Preferences >
Network > Device Name, and choose a network adapter from the Network Adapter drop-down menu.
Your system administrator will tell you which network adapter to choose. In general, you should
choose the adapter that is most likely to provide permanent connectivity or the adapter that is always
enabled—even if it is not plugged in. Avoid choosing a wireless card.
Note : This setting is used for network identification, not audio transmission. You do not need to
change this setting once it is established unless you are permanently removing or disabling the
selected network adapter.
Reference: IPCUserGuide.pdf
Hope it helps.
Anand
Please rate helpful posts by clicking on the stars below the right answers !!
