06-09-2016 03:00 AM - edited 03-19-2019 11:13 AM
i have cisco cme 10.5. 8841 sip phones are registered with cme. Issue i am facing is phone cannot handle multple calls? How do i check What is the issue? For Extention to Extension call, Phone gives busy signal for 2nd call. For Outside PRI call, Phone shows a long tone but the call doesnot land on extension.
Help!!!
Configs are:
voice register pool-type 8841
xml-config maxNumCalls 4
xml-config busyTrigger 2
xml-config custom sshAccess 0
phoneload-support
num-lines 4
description Cisco SIP Phone 8841
reference-pooltype 6921
voice register dn 1
number 611050
name Conference Phone
voice register pool 1
busy-trigger-per-button 1
id mac AC44.F212.B9FE
type 8841
number 1 dn 1
dialplan 1
dtmf-relay sip-kpml
voice-class codec 1
username admin password cisco
no vad
06-09-2016 04:44 AM
Hi Amjad,
Can you change the busy-trigger-per-button 1 to busy-trigger-per-button 2 under voice register pool 1 , reset the phone and test.
Manish
06-09-2016 05:07 AM
No its still the same. Even extensions see it busy. can you tell me how to configure multiple lines on 8841 phone? Following is what i did?
number 1 dn 1
number 2 dn 1
number 3 dn 1
where dn 1 and 13 have same extension number 601.
06-09-2016 05:16 AM
Configuration for SCCP and SIP shared lines as well as Multiple calls per line config is explained in the following link
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeadm/cmebasic.html#17513
Manish
