Walkthrough Wednesdays
472
cisco cube and dropped calls
Dear all,
we have cucm  10.5.2.11900-3 and cisco cube  C2900 Software (C2900-UNIVERSALK9-M), Version 15.4(3)M4, sometimes (I can't find logic..)our calls dropped with Aastra MX-One tranzit switch. In real Time MOnitoring tool i see normal call clearing. Our provider see "User/switching equipment congestion"
debug ccsip error in cube:
191917: *Feb 25 08:46:11.097 CET: //-1/xxxxxxxxxxxx/SIP/Error/voipCodec_to_rtpAv pCodec:
Unexpected VoIPCodec Type :No Codec
SIP: (551984) Group (a= group line) attribute, level 65535 instance 1 not found.
SIP: Attribute mid, level 1 instance 1 not found.
*Feb 23 12:44:05.071 CET: //662206/C42ADA800002/SIP/Event/sipSPICreateRpid: Received Octet3A=0x81 -> Setting ;screen=yes ;privacy=off
*Feb 23 12:44:05.071 CET: //662206/C42ADA800002/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SPI_EVENT
*Feb 23 12:44:05.267 CET: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_MEDIA_EVENT
*Feb 23 12:44:05.267 CET: //662206/C42ADA800002/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
*Feb 23 12:44:05.267 CET: //662206/C42ADA800002/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:109, resp_code:0, container:237DDEA8
*Feb 23 12:44:05.267 CET: //662206/C42ADA800002/SIP/Event/sipSPICreateRpid: Received Octet3A=0x00 -> Setting ;screen=no ;privacy=off
*Feb 23 12:44:05.271 CET: //662206/C42ADA800002/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
*Feb 23 12:44:05.271 CET: //662206/C42ADA800002/SIP/Event/Session-Timer/sipSTSLMain: dir:2, method:109, resp_code:200, container:237E6B98
*Feb 23 12:44:08.259 CET: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
*Feb 23 12:44:10.755 CET: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_OPTIONS_RESP
*Feb 23 12:44:23.451 CET: //662222/CF7E06000002/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
*Feb 23 12:44:23.451 CET: //662222/CF7E06000002/SIP/Event/Session-Timer/sipSTSLMain: dir:2, method:102, resp_code:0, container:237E40A0
*Feb 23 12:44:23.455 CET: //662222/CF7E06000002/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_PASS_ST_PARAMS, SE Value:1800, SE Refresher:none, Min-SE Value:1800, flags:2011
*Feb 25 08:48:45.494 CET: //-1/xxxxxxxxxxxx/SIP/Error/voipCodec_to_rtpAvpCodec:
SIP: (706704) Group (a= group line) attribute, level 65535 instance 1 not found.
SIP: setup attribute, level 1 instance 1 not found.
SIP: connection attribute, level 1 instance 1 not found.
SIP: Attribute label, level 1 instance 1 not found.
SIP: a=framerate attribute, level 1 instance 1 not found.
*Feb 25 08:48:45.506 CET: //706704/3969ED000002/SIP/Error/sipSPI_ipip_upd_2833_dtmf_params:
Unable to find proper instance for FMTP
SIP: fmtp attribute, level 1 instance 0 not found.
Unable to acquire event mask for rfc2833
*Feb 25 08:48:45.506 CET: //-1/xxxxxxxxxxxx/SIP/Error/voipCodec_to_rtpAvpCodec:
SIP: (706703) Group (a= group line) attribute, level 65535 instance 1 not found.
*Feb 25 08:48:50.734 CET: //-1/xxxxxxxxxxxx/SIP/Error/httpish_msg_free:
Freeing NULL pointer!
thank you in advance!
1 REPLY 1
Abhay Singh Reyal
Enthusiast
I think you have not pasted the entire debug from CUBE. Provide the call flow , calling and called number with exact time stamp.
Collect the debug voip ccapi inout and ccsip messages. Attach the entire debugs for the call.
Abhay Reyal
Abhay Singh Reyal
The Only Way To Do Great Work Is To Love What You Do. If You Haven’t Found It Yet, Keep Looking. Don’t Settle
Content for Community-Ad
Spotlight Awards 2021
