ozden ozdugun
Beginner
Cisco sip trunk cube problem
my system is  cucm 8.6.2 -s,ip to cisco 3925 router to sip to telco
I couln't call iphone to outside but ı can ringing outside to iphone but couldn't call
ı added configuration and ccsip inout debug at the attached
2 REPLIES 2
Nathan Gageby
Enthusiast
Could you elaborate on the call flow?  Maybe something like this?  Phone <-> CCM <-> SIP Trunk <-> 3925 <-> PRI <-> carrier
Then provide an idea of what calls are failing and in what direction?
I would also recommend you consider another set of dial-peers.
dial-peer voice 1001 voip
description *** OUT PG ***
destination-pattern 05.........
session protocol sipv2
session target ipv4:213.254.158.116
voice-class codec 1
dtmf-relay rtp-nte
dial-peer voice 1002 voip
translation-profile outgoing CUCM
destination-pattern 08505281...
session target ipv4:10.29.147.5
voice-class codec 1
dtmf-relay rtp-nte
_________________________
The red text indicates potential issue that could cause a loop.  You can limit this with the ^ and $ to note the start and end of a digit string but will only ever match the exact digit count between the two characters.  You may want to consider incoming uri and steering codes.
Hi Nathan;
not pri
CUCM-SIP TRUNK - Cisco 3926 - SIP TRUNK -TELCO
Ourproblem is when we try to call iphone to outsite no call enable.but outside to iphone we see timer callaing.iphone hear outside voice but outside couldn't hear iphone voice
Content for Community-Ad
Spotlight Awards 2021
