Hello, I'm trying to run a SIP trunk between Cisco and Avaya and malfunctions. Since I can generate avaya called correctly. In Cisco UC560-I can not generate calls and the trunk is not lifted and the Avaya logs record authentication failure occurs.
Logs:
Received:
SIP/2.0 407 Proxy Authentication Required
Via: SIP/2.0/TCP 192.168.124.1:5060;branch=z9hG4bKB3D586
To: <sip:826579@192.168.27.126>;tag=871890956*1*016asm-callprocessing.sar2132453312~1365688874751~-861664983~1
From: "Robert Cepero" <sip:83135@192.168.124.1>;tag=A4CE32C-1FAC
Call-ID: 7BC6ECD1-A1E611E2-8983AE3E-C1A0DC52@192.168.124.1
CSeq: 101 INVITE
Timestamp: 1365688606
Proxy-Authenticate: Digest realm="bancoestado.cl", qop="auth", opaque="1234567890abcedef", nonce="13df966770067dbf8a6edf2919b369448962c2afb74", algorithm=MD5, stale=false
Server: AVAYA-SM-6.2.3.0.623006
Content-Length: 0
