335
Highlighted
Participant
Cisco spark and ringin delay
Hi all,
i have a cissco spark configured and associated to my DN.
As remote destination i have my spark sip URI.
Problem is desk phoen and spark app will ring together even if i set wit timer=30.
CUCM version is 11.5
I would like spark app will ring after 3o second
2 REPLIES 2
Highlighted
The various Remote Destination timers do not apply to Spark RDs. Simultaneous Ring is the expected behavior.
Highlighted
Not at all dear Jonathan,
spark deviuce has a DN but it rings by using remote destination (SIP) uri.
I found out how to get the wait timer to work.
1) User-->enable mobilty
2) create a remote destinatio profile
3) in rd device delete and crete the remote destination
4) enable mobility with remote ddest profile you created
5) disable mobility and enable extend and connect
the funny things (in cucm 11.5) is if you change wait timet then spark beging to ring togehter with other device
You have to disable e re enable extend end connect to get changes to wait timer  operational
