Cisco UC Product Software Integration Standards Guide
mazinahsan
Is there a guide available for Standards to maintain for software application integrations/interactions with different UC Products. Defining Cisco standard recommended practices or approved procedures for application integration/interaction with its UC products.
Mazin
carolts
The information you are looking for is contained in the Unified Communications Technical Information Sites.  The landing page for the sites is located at http://cisco.com/go/unified-techinfo
In the right-hand navigation panel you will find links for the Release Compatibility Matrices for both IPT and Contact Center releases.  This show the combinations of Unified Communications product releases which have been tested together for compatibility and released as a system.
Similar information for releases not contained in the matrices is found in the System Compatibility Tool, listed just below the matrices on the landing page.
Hope this answers your question.
Carol Thorsten-Stein
carolts@cisco.com
