Cisco Unity 4.x not recognising DTMF tones from phones
spencek75
I have cisco call manage 4.x and Unity 4.x . I have set up IVR  but the IVR does not accept DTMF tones. Any suggestions anyone
5 Replies 5
Jaime Valencia
Is caller input enabled in Unity?
Have you confirmed DTMFs are reaching Unity with the port status monitor?
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
I checked and caller input is enabled in unity
Can you tell be how to check if DTMF tones are reaching the Unity. Thanks
Go to the Unity tools and you'll find the port status monitor there, open up all ports you have for inbound and then watch the output, if Unity is receiving the DTMFs you'll see the messages and the DTMF it received.
If you don't see any DTMFs messages then most lilely DTMFs are never reaching Unity and the problem is somewhere else.
java
java
I now realise that the problem is intermittent you will be sucessful sometimes but not others. I opened port staus monitor but did not know how to open all ports for inbound . I pressed a button called start all monitors but did not see anything in the event windows. Please see attached document
I am wondering if the gateway could be the problem. I am using AS5300 as the gateway
