02-16-2017 06:57 PM - edited 03-19-2019 12:07 PM
I am currently running Cisco unity connection 8.6 publisher and subscriber. There are some duplicate extensions in it. When I am trying to delete the extensions I am getting the error:
"OBJECT NOT FOUND USER"
Please see attached error file for same. I tried to do research but was not able to find a way to fix this issue. Your help would be highly appreciated.
Thanks & Regards
Rohit.
Solved! Go to Solution.
02-19-2017 05:39 PM
Sounds like you have replication issues and incorrect data across servers.
Try to get the database SYN by following the links below.
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unity-connection-version-20/112030-delete-user-unity-connect-00.html
https://supportforums.cisco.com/discussion/12376276/cant-delete-user-unity-object-not-found
If it is not working, you may need to open a TAC case to clean up the database.
02-16-2017 08:27 PM
02-16-2017 11:05 PM
Thanks for the reply. I did download the .csv file as you recommended. When I checked the file I could not see the duplicate entry there. However, when I search the user with the name in Unity connection I can still see the duplicate entry. I am not sure why it is showing it. Please have a look at the attached file for the duplicate name.
Thanks & Regards
Rohit.
02-19-2017 05:39 PM
02-19-2017 06:37 PM
Hi Jasperliang,
I tried to run the SQL command mentioned in the link above it says
"NO RECORD FOUND"
I think it would be best to open a TAC case with Cisco. Thanks for your help and support.
Kind Regards
Rohit Mangotra.
