We are in a planning phase for Unity Connection 8.X on Cisco UCS C-Series. The Cisco Unified Communications SRND 8.0 states that requires reserving one physical core per physical server.
what does it really mean?
Solved! Go to Solution.
One core is needed for ESXi scheduler for each UCS server running UCON virtual machine.
HTH,
Chris
See sample depiction below of applications and physical core usage on a server with 2 CPUs and 8 total physical cores. In white is the reservation of one physical core.
Regards.
HTH,
Chris
Regards.
