Showing results forĀ
Search instead forĀ
Did you mean:Ā
cisco unity connection cluster 10.5 issue
abd88elhak
hi
i have a cisco unity connection cluster 10.5 and i have juste restoring the databse of the publisher and after reload : there no communication between cluster servers each one is primay .
please find the attched files
regards
abd88elhak
Any update about my problem please
Can you post the output of the "show cuc cluster status" from the CLI of each server?
please find the attached file
regrads
Could you try to follow this link to fix the issue?
http://www.cisco.com/c/en/us/support/docs/unified-communications/unity-connection/116683-problemsolution-product-00.html
