04-24-2019 02:24 AM
For power maintenance, we have rebooted the CUCM cluster recently. Post reboot, the Cisco Unity DRF page options are not working. I can log in to DRF GUI of Cisco Unity but I cannot access any features ( backup history, status, etc). Even in the CLI mode " utils Disaster Recovery Status backup " command not giving any output.
I suspect the IPsec.pem certificate got crashed for some reason post reboot. But I can view the certificate it is valid till Jun 2023.
I tried restarting DRF local & DRF master services but no luck. Please help me on this
Solved! Go to Solution.
04-24-2019 03:48 PM
Yes that’s the issue.
Delete the old ipsec-trust on secondary node and replace it with the regenerated one on the primary node.
Restart the drf local and master.
Please let me know.
Carlo
04-24-2019 03:21 AM
Which version of UCNx are you running?
Please let me know.
Carlo
04-24-2019 04:40 AM
Cisco UCNx version 9.1.2. Also I found there is a expired IPsec trust certificate on the secondary Unity(where DRF not working) Please advice
04-24-2019 08:41 AM
Can someone please help. Should I delete the expired certificate and regenerate new one?
04-24-2019 11:51 AM
04-24-2019 12:32 PM
Hi Carlo,
Yes it is a CUC cluster with two nodes(primary & secondary). DRF is working fine on primary. IP sec certificate is valid on both nodes. The only issue I see that, the secondary node (where the DRF issue) has the expired IPsec trust certificate of primary node
1. Should I delete the expired Ipsec certificate?
2. Shall I upload the existing primary node IPsec certificate to secondary node as a IPsec-trust?
3. or should I regenerate the certificates on primary node then download the certificate and upload it as ipsec-trust on the secondary node?
Please let me know the exact procedure
04-24-2019 03:48 PM
Please let me know.
Carlo
05-09-2019 08:52 AM
Issue got resolved. I regenerated the Ipsec certificate in Primary UC and uploaded the same as Ipsec-trust in secondary UC. And restarted the DRF local & master services.
04-04-2023 11:09 AM
I had this exact same issue on a single node Unity Connection system. DRS was completely unresponsive when I would go into the web interface. I tried rebooting the system which did nothing. Even though the IPSEC certificate wasn't set to expire for another four years, I decided to regenerate it. After doing that I restarted the Cisco DRF Master and Cisco DRF Local services. That fixed the issue. I was then able to get into the Disaster Recovery System web pages and navigate normally. So this issue doesn't only impact multiple node Unity Connection platforms.
