341
Beginner
Cisco Unity connection DRF page options are not working
For power maintenance, we have rebooted the CUCM cluster recently. Post reboot, the Cisco Unity DRF page options are not working. I can log in to DRF GUI of Cisco Unity but I cannot access any features ( backup history, status, etc). Even in the CLI mode " utils Disaster Recovery Status backup " command not giving any output.
I suspect the IPsec.pem certificate got crashed for some reason post reboot. But I can view the certificate it is valid till Jun 2023.
I tried restarting DRF local & DRF master services but no luck. Please help me on this
1 ACCEPTED SOLUTION
Re: Cisco Unity connection DRF page options are not working
Yes that’s the issue.
Delete the old ipsec-trust on secondary node and replace it with the regenerated one on the primary node.
Restart the drf local and master.
Please let me know.
Carlo
Please rate all helpful posts "The more you help the more you learn"
7 REPLIES 7
Which version of UCNx are you running?
Please let me know.
Carlo
Beginner
Cisco UCNx version 9.1.2. Also I found there is a expired IPsec trust certificate on the secondary Unity(where DRF not working) Please advice
Beginner
Can someone please help. Should I delete the expired certificate and regenerate new one?
Sorry for delay .
Yes you should regenerate the ipsec certificate without deleting it.
If it’s a cluster, regenerate the certificate on both nodes and upload the
new one to the other host.
Restart the drf master service.
Carlo
Highlighted
Beginner
Hi Carlo,
Yes it is a CUC cluster with two nodes(primary & secondary). DRF is working fine on primary. IP sec certificate is valid on both nodes. The only issue I see that, the secondary node (where the DRF issue) has the expired IPsec trust certificate of primary node
1. Should I delete  the expired Ipsec certificate?
2. Shall I upload the existing primary node IPsec certificate to secondary node as a IPsec-trust?
3. or should I regenerate the certificates on primary node then download the certificate and upload it as ipsec-trust on the secondary node?
Please let me know the exact procedure
Please let me know.
Carlo
Beginner
Issue got resolved. I regenerated the Ipsec certificate in Primary UC and uploaded the same as Ipsec-trust in secondary UC. And restarted the DRF local & master services.
Content for Community-Ad
August's Community Spotlight Awards
