09-06-2018 08:06 AM - edited 03-19-2019 01:32 PM
Hi everybody,
My customer wants upgrade entire UC environment (CUCM 9, IM&P 9, UCCX 9, CUAC Business 9) to 11.5
I've doubt only about upgrade CUAC.
CUAC Business 9 is installed in BE6000 (Windows 2008R2 SP1 64bit, SQL 2008)
VM is 1vCPU, 40Gb HD, 4Gb RAM
I checked compatibiity matrix for CUAC Adv 11 and Win 2008R2 is supported and SQL 2008 is supported.
The only difference is the capacity of HD. CUAC Adv wants 80Gb HD.
I wanted to install the software directly on the old VM. It's works? Or I have to do a fresh installation on other VM?
Solved! Go to Solution.
09-07-2018 07:16 AM
I meant the docs on your question on whether you could upgrade it or not directly, yes, you can resize, but that's not a Cisco procedure, you can find info on resizing a windows VM on google.
09-06-2018 09:17 AM
Did you review the upgrade chapter of the admin and install guide for CUACA?
09-07-2018 01:33 AM
Jaime,
I read the whole document, but never talk about resize.
There are only listed vmware Guest Machine Requirements.
09-07-2018 07:16 AM
