CUACA Login Problem
Maheer Brown
Hi Guys
I keep getting "the following error was returned: Invalid login name" when trying to login to the CUACA Client
Everything seems to created as per the PDF
Any ideas?
M
Ankoor Bek
Hi Maheer,
Please check the below:-
1) Install the client on the sever and check if you can login with the same credentials.
2) Please check if the operators IP phone MAC is added to the application user in CUCM.
If the above have negetive results, please collect the Wireshark packet captures and OPR agent logs from the client PC and attache it here.
Ankoor Bek
